I receive the following error in the openhab console:
22:54:15.918 [WARN ] [e.core.thing.binding.BaseThingHandler] - Handler GenericThingHandler of thing mqtt:topic:MQTTGoldeneyeBroker:Ventilatie tried updating channel Ventilatie_Werkingsmode although the handler was already disposed.
Item:
Number Ventilatie_Werkingsmode "State is [MAP(VentilatieWerkingsMode.map):%s]" {channel="mqtt:topic:MQTTGoldeneyeBroker:Ventilatie:Ventilatie_Werkingsmode", autoupdate="false"}
As I understand, the MQTT broker received an status update on the topic linked to the item, but is unable to update the item.
Strange thing is: it is updating, so to me everything looks normal, but i receive the warning.
Can this be ignored?
I have an update on the issue.
I’ve also set a rule to make my chromecast say a few words on an item change.
Both items have nothing to do with eachother, but every time that warning fires, my chromecast repeated the message it was casting earlier.
in the mqtt.things file:
Thing topic Ventilatie "MQTT Ventilatie" {
Channels:
Type number : Ventilatie_Werkingsmode "Werkingsmodus ventilatie" [ stateTopic="OpenHAB/Ventilatie/Mode", commandTopic="Beckhoff/Ventilatie/Mode/Value"]
The channel and the item have the same name, this is wat OpenHAB doesn’t seem to like.
I thought Items and Channels were different, so double-naming wouldn’t be an issue. Obviously I was wrong.
After a reboot of OpenHAB, and the correction of double channel and item naming. The warning disappeared.
