Hi I was hoping someone could help me get my ecobees reporting into openhab properly. I used this to get one ecobee to work and now that I have updated the file with an new ecobee thermostat it just says they are duplicate values and doesnt report anything.
Any help is greatly appreciated.
Number Ecobee_Temperature "Ecobee Temperature [%.1f °F]" (gRuntime) { ecobee="<[main.3*3#runtime.actualTemperature]" }
Number Ecobee_Humidity "Ecobee Humidity [%d %%]" (gRuntime) { ecobee="<[main.3*3#runtime.actualHumidity]" }
Number Ecobee_DesiredCool "Ecobee Desired Cool [%.1f °F]" (gRuntime) { ecobee="<[main.3*3#runtime.desiredCool]" }
Number Ecobee_DesiredHeat "Ecobee Desired Heat [%.1f °F]" (gRuntime) { ecobee="<[main.3*3#runtime.desiredHeat]" }
Number Ecobee_Temperature "Ecobee Temperature [%.1f °F]" (gRuntime) { ecobee="<[up.5*8#runtime.actualTemperature]" }
Number Ecobee_Humidity "Ecobee Humidity [%d %%]" (gRuntime) { ecobee="<[up.5*8#runtime.actualHumidity]" }
Number Ecobee_DesiredCool "Ecobee Desired Cool [%.1f °F]" (gRuntime) { ecobee="<[up.5*8#runtime.desiredCool]" }
Number Ecobee_DesiredHeat "Ecobee Desired Heat [%.1f °F]" (gRuntime) { ecobee="<[up.5*8#runtime.desiredHeat]" }
main.appkey=1
up.appkey=2
base.appkey=3
# the application scope used when authorizing the binding
# choices are smartWrite,smartRead, or ems, or multiple (required, comma-separated, no spaces)
main.scope=smartWrite
up.scope=smartWrite
base.scope=smartWrite
I was using it but put the name inbetween the ecobee and the command. ecobee_2_temperature. I was using VS code and it accepted that so I tried it. The paper ui kept many various names in the config so I tried to clear my cache to delete those and start over there and that bricked my java on the system. I posted a thread about it. I may use a backup to fix it. There are around 6 or 8 different names I tried for the ecobees, I was trying to remove those.
@mhilbush vs code was the way I got it to work initially so I think I can do it again I just need to clear all those old names out and start over. I deleted the files and bindings and they stayed there when I reinstalled so I am going to find the commands and location to uninstsal in karaf tonight.
Any idea how to delete this whole thing? I deleted the cfg and uninstalled the binding and reinstalled from the paper UI and it didnt work out. I think if I can delete this, I can probably get it to work.
It does I have deleted it a couple of times I will try again. I had some technical difficulty but I am starting to understand alot of the functions and finishing up alot of loose ends: unifi, nest, echo control, this ecobee binding is being stubborn but I’ll get it under control!
Hi guys I finally had a chance to redo all this from scratch and now everything is reporting as it should be. I had to many things happening in the files and needed a clean slate. I appreciate all the input it was all valuable. Now to finish installing basic function and habpanel then it’ll be time to move to hard part rules .
