My rule looks like this now, but I dont see it working still
rule "Flexion power to ON"
Time cron "0 0 7 ? *MON-SAT *" or
Item OnePlus5 changed to ON
if (OnePlus5.state == ON && now.getHourofDay() >=7 && now.getHourofDay() < 17) {
mqttActions.publishMQTT("cmnd/sonoff-flexion/POWER", "On")
sendTelegram("bot1", "Flexion Microscope is switched ON")
logInfo("Info","Flexion power ON Rule fired")
Doesnât look far wrong to me.
I would move the logInfo to before the if() line, then it will tell the truth about the rule firing.
You can always put another logInfo inside the if-block to see if you pass the conditions.
What does openhab.log tell you about it?
2019-02-22 11:20:30.589 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Flexion power to ON': 'getHourofDay' is not a member of 'org.joda.time.DateTime'; line 76, column 33, length 16
Okay, that should cause you to look closely at the use of that in your rule. Why would it fail for you, but work for other people? Compare carefully with other examples of usage, e.g. earlier on in this thread.
.getHourOfDay
Rules are (very) case sensitive.
We all make mistakes like this and they are very easy to overlook, but not that difficult to find using the error reporting.
If you are not yet using VSCode as a rule editor, I would recommend it. It catches typos like that. It is another thing to set up and something else to learn to use, but will pay off in the long run.
Actually I did install and setup VScode. But I havenât figured out how to enable write priviledges to the conf files. My OH setup is on a synology docker. So I canât save anything I change with VScode
I am getting this error with my rule which triggers a fan when temperature goes to 37 or higher
2019-03-11 21:10:43.251 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Rackfan power to ON': An error occurred during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(T,org.eclipse.xtext.xbase.lib.Procedures$Procedure1) on instance: null
This is the rule
val mqttActions = getActions("mqtt", "mqtt:broker:mosquitto")
rule "Rackfan power to ON"
Time cron "0 0 10 ? * MON-SUN *" or
Item Sonoffps3_Temperature received update
if ((Sonoffps3_Temperature.state => 37) && now.getHourOfDay() >=10 && now.getHourOfDay() <=18) {
mqttActions.publishMQTT("cmnd/sonoff-rackfan/POWER", "ON")
sendTelegram("bot1", "Rackfan is switched ON as temperature is above 37°C" )
logInfo("Info","Rackfan power ON Rule fired")
else if ((Sonoffps3_Temperature.state < 38) && now.getHourOfDay() >=10 && now.getHourOfDay() <=18) {
mqttActions.publishMQTT("cmnd/sonoff-rackfan/POWER", "OFF")
logInfo("Info","Rackfan power OFF Rule fired")
I was trying to understand that thread to create a rule for my needs, unfortunately it throws this error when saving already:
2022-05-19 21:31:41.494 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'automation.rules' has errors, therefore ignoring it: [136,63]: no viable alternative at input '&&'
This is the rule. A dehumidifier should only work when a certain humidity is reached AND when there is enough PV power (my power meter shows negative values when it provides power to the grid, and positive when drawing from it. Hence the value)
Time cron "0 0/5 * * * ?"
if ((FeuchteNodemcu2.state as DecimalType).floatValue >= 61) && ((DSWirkleistung.state as DecimalType).floatValue <= -1000) {
ShellyPlug2Output.sendCommand (ON)
else if ((FeuchteNodemcu2.state as DecimalType).floatValue <= 55) {
ShellyPlug2Output.sendCommand (OFF)
