Put the nStatus variable as a global variable.
When the timer checks it, the rule has finished and the variable “disapeared”
And initialise strPlaysound
var strPlaySound = ""
I’m pretty sure that the code should work as intended.
tStatus as well as nStatus are defined as global (please confirm that you put the definition at top of the file)
strPlaysound doesn’t need to be initialized, as it’s set in the switch case construct.
But there is something going wrong with nStatus, as no case other than default is executed.
Please add some logging and an .intValue:
// always define global var and val at top of the file!
var Timer tStatus = null // timer for house status
var Number nStatus = 0 // step for playing status
rule "House Door Status"
Item HouseCheck received command ON // maybe better use received command ON
Kitchen_Volume.sendCommand(40) // set volume
tStatus?.cancel // delete existing timer
nStatus = 0 // reset timer
tStatus = createTimer(now.plusSeconds(3), [ | // start initial timer
var String strPlaysound = "" // which file to play
nStatus = nStatus + 1
logInfo("statuscheck","Timer gets executed. nStatus = {}",nStatus) // some logging...
switch (nStatus.intValue) { // just to be sure, it's an Integer
case 1: { // first run
strPlaysound = if (Front_Door_Status.state == OPEN) "FrontisOpen.mp3" else "FrontisClosed.mp3" // ternary operator is way more simple
case 2: { //second run...
strPlaysound = if (Garage_Door_Status.state == OPEN) "GarageisOpen.mp3" else "GarageisClosed.mp3"
case 3: {
strPlaysound = if (SB_02_P1.state == OPEN) "ShedisOpen.mp3" else "ShedisClosed.mp3"
case 4: {
strPlaysound = if (Front_Lights.state == ON) "FrontLightsOn.mp3" else "FrontLightsOff.mp3"
case 5: {
strPlaysound = if (Back_Lights.state == ON) "BackLightsOn.mp3" else "BackLightsOff.mp3"
case 6: {
strPlaysound = if (Back_Door_Status.state == OPEN) "BackDoorOpen.mp3" else "BackDoorClosed.mp3"
default: { // last run
Kitchen_Volume.sendCommand(20) // reset volume
HouseCheck.sendCommand(OFF) // reset triggering item
tStatus = null // reset timer
if (nStatus < 7) { // if not last step
playSound(strPlaysound) // play sound
tStatus.reschedule(now.plusSeconds(3))
} // reschedule timer
Hi Udo, I didn’t put the above in the rule but I did do what it said with
var Number nStatus
being at the top.
The rule is exactly as per posted and sorry to say I don’t know how to add logging.
I also made changes to the brackets from your original reply as it would not load as is but may have got it wrong.
James
Hi Again, with the last code you posted I get "No viable alternative at input ‘rule’ 6,1. I can’t see the culprit bracket.
Sorry to keep posting, Im not home to hear it but it looks like its working. The previous error "No viable alternative at input rule was due to the = sign after the var number nStatus. I removed it and manually fired it off. here is the log.
2019-09-12 10:24:34.030 [ome.event.ItemCommandEvent] - Item 'HouseCheck' received command ON
2019-09-12 10:24:34.047 [vent.ItemStateChangedEvent] - HouseCheck changed from OFF to ON
2019-09-12 10:24:35.731 [ome.event.ItemCommandEvent] - Item 'Kitchen_Volume' received command 40
2019-09-12 10:24:35.749 [vent.ItemStateChangedEvent] - Kitchen_Volume changed from 20 to 40
2019-09-12 10:24:38.744 [INFO ] [e.smarthome.model.script.statuscheck] - Timer gets executed. nStatus = 1
2019-09-12 10:24:40.475 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from UNDEF to Notification
2019-09-12 10:24:40.520 [vent.ItemStateChangedEvent] - Gateway_AmbientLight changed from 851 to 828
2019-09-12 10:24:42.746 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from Notification to UNDEF
2019-09-12 10:24:44.882 [INFO ] [e.smarthome.model.script.statuscheck] - Timer gets executed. nStatus = 2
2019-09-12 10:24:45.292 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from UNDEF to Notification
2019-09-12 10:24:46.272 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from Notification to UNDEF
2019-09-12 10:24:49.202 [INFO ] [e.smarthome.model.script.statuscheck] - Timer gets executed. nStatus = 3
2019-09-12 10:24:49.668 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from UNDEF to Notification
2019-09-12 10:24:50.717 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from Notification to UNDEF
2019-09-12 10:24:53.457 [vent.ItemStateChangedEvent] - Gateway_AmbientLight changed from 839 to 790
2019-09-12 10:24:53.592 [INFO ] [e.smarthome.model.script.statuscheck] - Timer gets executed. nStatus = 4
2019-09-12 10:24:54.196 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from UNDEF to Notification
2019-09-12 10:24:55.208 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from Notification to UNDEF
2019-09-12 10:24:58.101 [INFO ] [e.smarthome.model.script.statuscheck] - Timer gets executed. nStatus = 5
2019-09-12 10:24:58.543 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from UNDEF to Notification
2019-09-12 10:24:59.557 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from Notification to UNDEF
2019-09-12 10:25:02.442 [INFO ] [e.smarthome.model.script.statuscheck] - Timer gets executed. nStatus = 6
2019-09-12 10:25:02.893 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from UNDEF to Notification
2019-09-12 10:25:03.883 [vent.ItemStateChangedEvent] - KitchenDisplay_MediaTitle changed from Notification to UNDEF
2019-09-12 10:25:06.802 [INFO ] [e.smarthome.model.script.statuscheck] - Timer gets executed. nStatus = 7
2019-09-12 10:25:06.817 [ome.event.ItemCommandEvent] - Item 'Kitchen_Volume' received command 20
2019-09-12 10:25:06.841 [ome.event.ItemCommandEvent] - Item 'HouseCheck' received command OFF
2019-09-12 10:25:06.846 [vent.ItemStateChangedEvent] - Kitchen_Volume changed from 40 to 20
2019-09-12 10:25:06.859 [vent.ItemStateChangedEvent] - HouseCheck changed from ON to OFF
So the Timer works as suggested, but there is no message played?
So more logging:
case 3: {
case 4: {
case 5: {
case 6: {
logInfo("statuscheck","Chose file {} to play.",strPlaysound) // some more logging...
Hi Udo,
I tested last night and you are correct nothing played. I could hear the volume go up and then when all timers finished the volume went down. I changed my default audio sync device at it works perfectly. I changed back and it does not play again. So, your rule works and I will work out why my Kitchen display will not work as it used to.
Thank you so much for all your patience and help.
James
Ah. Of course you have to set the audio sink if you are using more than one. See
for details.
