[SOLVED] Multiple send telegram message
I want the rule to send a single message only when it exceeds the indicated value, because now he is sending multiple
rule "assoribimento massimo  telegram"
	Item Watt changed
if (Watt.state > 2700){
sendTelegram("bot1", "ATTENZIONE assorbimento oltre i 2.7 Kw!")
Thanks for your help
David
Try using == instead of > else you will get a message on every change when above 2700. If the change happens fast then you may want to use something like:
if (Watt.state > 2700 && Watt.state < 2705){
Adjust the numbers to fit your needs.
does not work
probably because the value changes quickly
var boolean wattTrigger = false // At the top of the rules file!!
    Item Watt changed
    if (Watt.state > 2700 && !wattTrigger) {
        wattTrigger = true  //Sets the trigger that we are over 2700
    if (Watt.state < 2700) wattTrigger = false // Resets the trigger
right!
it’s the same logic of the flags on arduino … I had not thought about it.
Now it works, thanks
Davide
Please mark the thread as solved, thank you
