I believe I am having exactly the same issue as yourself, apart from my my.openhab account seems to be online and is sending information over to the website, but I cannot access it via the mobile app.
Could you please describe how you removed the certificate from the keystore and how to download the new one? The link you have put up just makes you to the my.openhab home page?
When I try to log in with the openhab app, I get the following in debug;
[DEBUG] [.r.i.resources.SitemapResource:107 ] - Received HTTP GET request at âsitemapsâ for media type ânullâ.
21:15:13.119 [DEBUG] [.r.i.resources.SitemapResource:228 ] - Received HTTP GET request at âhttp://192.168.1.140:8080/rest/sitemapsâ.
21:15:13.515 [DEBUG] [.r.i.resources.SitemapResource:146 ] - Received HTTP GET request at âsitemaps/My/nullâ for media type ânullâ.
21:15:13.521 [WARN ] [o.u.i.items.ItemUIRegistryImpl:471 ] - Cannot find page for id ânullâ.
21:15:13.523 [DEBUG] [.r.i.resources.SitemapResource:211 ] - Received HTTP GET request at âhttp://192.168.1.140:8080/rest/â for the unknown page id ânullâ
The myopenhab website bits are working but I cannot get the app working. I believe it to be a certificate issue as described in the above post, can anyone help me with how to do this?
Hi! I think itâs not the same problem as mine, because my openhab instance was offline, and yours is online.
Please check the following settings in your mobile app:
openHAB Remote URL - it should be https://my.openhab.org
Ignore SSL certificate and Ignore SSL hostname should be unchecked.
Also according to the log, it seems that your app is successfully connecting, but canât retrieve the list of sitemaps. You may validate successfull connection by selecting âMenuâ -> âopenHAB infoâ. If is shows not empty fields, than definitely the connection is successful, so the problem is not with certificates. What is displayed when you select âMenuâ -> âSelect default sitemapâ?
Thank you for your response. I have tried the settings you speak of, however I am still unsuccessful. The remove URL is set exactly as you have it (apart from the bold typeâŠ) I have left the local blank, although I believe in my case it should be filled with http://192.168.1.140:8080
I am getting the following warnings on openhab log when I try with my iPad (multiple tries at the bottom);
2015-11-02 18:25:58.113 [WARN ] [org.eclipse.jetty.io.nio ] - javax.net.ssl .SSLException: Inbound closed before receiving peerâs close_notify: possible tru ncation attack?
2015-11-02 18:25:59.067 [WARN ] [o.u.i.items.ItemUIRegistryImpl] - Cannot find p age for id ânullâ.
2015-11-02 18:26:09.802 [WARN ] [o.u.i.items.ItemUIRegistryImpl] - Cannot find p age for id ânullâ.
2015-11-02 18:26:58.802 [WARN ] [o.u.i.items.ItemUIRegistryImpl] - Cannot find p age for id ânullâ.
Interestingly when I try from my laptop with the following link https://my.openhab.org/openhab.app?sitemap=My (adapted from the one you get when you sign into my.openhab online) I get the following error and 504 server error on the screen;
2015-11-02 18:36:06.036 [ERROR] [.myopenhab.internal.MyOHClient] - Socket.IO error: com.github.nkzawa.engineio.client.EngineIOException: xhr post error
2015-11-02 18:36:06.044 [INFO ] [.myopenhab.internal.MyOHClient] - Disconnected from my.openHAB service (UUID = 770bdbd7-xxxx-xxxx-xxxx-1026cec57662, base URL = http://localhost:8080)
2015-11-02 18:36:11.622 [INFO ] [.myopenhab.internal.MyOHClient] - Connected to my.openHAB service (UUID = 770bdbd7-xxxx-xxxx-xxxx-1026cec57662, base URL = http://localhost:8080)
I am using the app version 1.7.1 and I am getting nothing under the details for OpenHAB version, OpenHAB UUID or openHAB secret so I donât think it is connecting properly. I do not have an option for SSL hostname, only SSL certificates, which remains unchecked. When I click select sitemap I do get the option of My Home which is the name I have given my sitemap (the file is however called My.sitemap) selecting this still makes no difference to the output.
I hope I can get this fixed as getting tablet access is key to my home automation project!
Hmm, what do you have at the first line of your âMy.sitemapâ file?
I have the file âhome.sitemapâ with the following first line:
sitemap home label=âSmart Homeâ
So, as you can see, the name of the file and the name of the sitemap are the same.
Also try to use only lowercase letters (I donât know if it matters, but what if yes?)
I hadnât read anywhere that the sitemap name had to be in between sitemap and label!
I had;
sitemap label=âMy Homeâ
Now I have the following and the app connects! (I still dont have any details under the OpenHAB info section of the app though, but small victories and all!!)
sitemap My label=âMy Homeâ
Thank you very much for your help, it really is very much appreciated!
