[solved] My.Openhab on Macbok
I run OpenHAB on a MacBook with OS X El Captain Version 10.11.2.
But OpenHAB does not connect to my.openhab.
UUID and secret are the same on the web and system, addon is in addon folder, myopenhab.persist has this content:
Strategies {
default = everyChange
Items {
gMyOpenHAB : strategy = everyChange*
Content of openhab.cfg:
security:option=OFF
persistence:default=myopenhab
Does anyone has an idea to fix this?
Thank you!
First we need to look into your openhab.log file. Please run openhab in debug mode then post the startup part of the log (removing possible usernames, passwords, uuids and secrets from the text :wink:
I stored the information in my dropbox:
From what I see my.openHAB bundle doesn’t start - there are no messages about myOH in your log at all.
So I wonder how you got secret file at all then?
Try to touch bundle file, maybe it is some problem with bundle loader…
I also recommend to upgrade to 1.8.0 bundle even if you are using 1.7 openHAB. It is available for download separately in docs section of my.openhab.org since today.
Solved the problem.
Terminal was running java 6, I installed JDK 8u66.
