[SOLVED] My rules are not working - Beginner
Hi
i’m new to openhab and have been playing around with programing some virtual items and rules for them, before i get all my IOT devices.
the problem is I have created some virtual items as scenes, and made some rules for them. but it seems to me that the rules are not running.
or at least they are not doing anything.
my rules are in the rules folder and the file is called RULES.rules, do i need to tell openhab to load that file ?
does it have any effect on this file that i am running some rules on " Rule Engine (Experimental)" ?
or is something wrong with my code ?
rule "Sunset Rule"
        Channel 'astro:sun:local:set#event' triggered END
    if( VirtualItem.state==ON ) {
    VirtualItem4.sendCommand(ON)
        //kveikir á deigi
    rule "Sunrise Rule"
        Channel 'astro:sun:local:rise#event' triggered END
        VirtualItem5.sendCommand(ON)
        //kveikir á kvöldi
rule "Night Rule"
      Time cron "0 0 0 ? ? MON,TUE,WED,THU,FRI *" or
      // Kveikir á nótt
      Time cron "0 0 1 ? ? SAT,SUN *"
      VirtualItem2.sendCommand(ON)
  1. You have two times the same rule “Sunrise Rule”. Each rule must be unic.
  2. The Structure is: rule, when, then, end. You have to many “end” in your code
  3. Each time you edit this file, the rules load immediately at openhab, you must do nothing.
After edit rules, please take a look on the logfiles, then you will see if you have some errors on your scripts: https://www.openhab.org/docs/administration/logging.html
As mentioned above you have more end’s than you need.
Both of your Time cron expressions are incorrect, see this link to assist with the correct format.
https://www.freeformatter.com/cron-expression-generator-quartz.html
Thanks for the help
