Hi there,
My BasicUI is working fine until a few days ago. Now, I can not see any image through MyOpenhab. Through Localhost works fine everything.
I have not changed any item and anything on sitemap. It seems something in myopenhab is not working fine.
Sometimes I get the message: “Offline: waiting for connection to become available” bt in the website appears like ONLINE. Other times I get an APACHE error of the address to my camera, but it is false because I type the address in the explorer and works fine…
How can I Troubleshoot?
First Photo is conected from LOCALHOST and also I tried with a DDNS address opening port JUST TO MAKE SOME TEST to CHECK THAT works fine (after that I will close it). But I cannot use myopenhab if I do not have image. 2 days ago, everything worked fine.
From LocalHost and DDNS:
From MyOpenhab:
Cameras: two DCS-932LB.
ITEM:
Webview url="http://<IP>/video.cgi" height=16
LOGS:
2018-08-11 12:37:35.347 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = <###>, base URL = http://localhost:8080)
2018-08-11 12:43:53.009 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2018-08-11 12:43:53.033 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = <###>, base URL = http://localhost:8080)
2018-08-11 12:44:11.308 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = <###>, base URL = http://localhost:8080)
2018-08-11 13:01:27.321 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2018-08-11 13:01:27.346 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = <###>, base URL = http://localhost:8080)
2018-08-11 13:01:45.592 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = <###>, base URL = http://localhost:8080)
