Today I was trying to set up some tasks in tasker to use myopenhab rest commands.
I had some error messages and then myopenhab stopped working.
Now i can still login on myopenhab.org, the system status says it’s operational, but i can’t connect using the android app.
Did I do something that messed everything up or is it just the service that’s not working properly?
Been trying to solve this for hours now, I cannot access through web and google assistant cannot reach openhab.
Luckily I’m not the only one with issues, let’s hope they can resolve this quickly!
Ray, I meant it was solved because it wasn’t a problem I caused with tasker.
It happened before that myopenhab was unstable and not working, but it took just maybe a day for it to work again.
I removed the [solved] tag just in case.
at io.socket.engineio.client.Transport.onError(Transport.java:71) [256:org.openhab.io.openhabcloud:2.4.0]
at io.socket.engineio.client.transports.PollingXHR.access$100(PollingXHR.java:19) [256:org.openhab.io.openhabcloud:2.4.0]
at io.socket.engineio.client.transports.PollingXHR$6$1.run(PollingXHR.java:124) [256:org.openhab.io.openhabcloud:2.4.0]
at io.socket.thread.EventThread$2.run(EventThread.java:80) [256:org.openhab.io.openhabcloud:2.4.0]
Caused by: java.io.IOException: 400
at io.socket.engineio.client.transports.PollingXHR$Request$1.run(PollingXHR.java:218) ~[?:?]
… 1 more
2019-05-29 16:55:00.116 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxxxxxxxxxxxxxxxxxxxxx, base URL = http://localhost:8080)
2019-05-29 17:32:32.269 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = xxx, base URL = http://localhost:8080)
Looks like the service is back. But I still get an error when trying to connect with the iOS app.
I am happy about that. Have this morning with the system changed what. At work i get no connection. Have been thinking all the time, what I have broken. But if you can not connect, the mistake will not be in my attitude.
