Failed to load resource: the server responded with a status of 500 (Internal Server Error)
YES YES YES It’s working again without reboot =)))! Great great thanks =)!
If you expereince error 500 -> Remember NOT TO USE AUTOFILL IN ANY KIND! Type everything by hand, and delete your browsercache/cookies before retry.
I needed restart cloud conector to recover cloud connection. Thanks!
im unable to connect openhab to google home after i removed it… ???
I’d leave it alone for a couple of hours and try again.
For future reference, whenever you suddenly have trouble with openHAB Cloud, it’s best to check the community and status.openhab.org before assuming it’s a problem with your system. I also learned this the hard way, and now it’s my first instinct whenever Google Assistant can’t connect to openHAB.
Ye im also beating myself senseless right now for deleting the application… spent 10 days straight setting everything up… when i try to add Openhab to Google home, it says “the settings cannot be updated. check your connection”
hello,
are there any openhab-cloud problems actually?
my cloud connector logs “error connecting to the openHAB Cloud instance”
Restart does not solve the problem
@digitaldan do you know some problems ?
ralph
have the same problem!
Looks like Linode made some networking change and severed all connections, everything is reconnecting right now, may be a little until everything comes back
+1, same problem (from France).
Didn‘t you read the post above yours ?
No need to mention your issue, as it was a provider mainenance and installations reconnecting slowly.
Very slowly!
…still down
Yep. Looks like the servers might have gone offline again.
Just check http://status.openhab.org/. Once it’s back up, assume it’ll be a few hours before your system reconnects (though it’s usually faster than that).
