I am new to rules. I am using openHABian on a raspberry pi.
I am using visual studio for my editor. I have used paper UI to configure my bindings and things and items and HABPanel to control switches. Everything is working fine manually. Now I want to automatically turn off the fireplace if the temperature in the room is above a value set on the HABPanel. Here is my simple code for the rule. It seems like the system does not even see the rule.
rule “Fireplace_off_over_temperature”
Temperature > Requested_Fireplace_temperature
Extraswitch.sendCommand(OFF)
I also tried this
Temperature.state > Requested_Fireplace_temperature.state
Extraswitch is the switch that controls the fireplace.
Temperature is the temperature from the sensor.
Requested_Fireplace_Temperature is the temperature set from a slider in HABPanel
Any help would be appreciated.
