Running openHAB 2.4.0-1 (Release Build) on RPi. House Demo sitemap and things all working.
I am trying to add my Leviton OmniPro2 controller into openHAB2.
The binding does not show up in searches using PaperUI. So I’ve followed many discussions/threads and have figured out that I need to manually install the binding.
I am not sure if I have the right file, but after much searching I found “jomnilink-1.3.0-SNAPSHOT.jar” on Github. Downloaded that file, copied it to /usr/share/openhab2/addons folder.
Added this to my “demo.things” file:
ntp:ntp:demo [ hostname=“nl.pool.ntp.org”, refreshInterval=60, refreshNtp=30 ]
Bridge omnilink:controller:home [ ipAddress="192.168.2.200", port="xxx", key1="xx:26:4CxxFF:xx:D3:xx:xx", key2="50:xx:96:xx:xx:xx:xx:03" ] { }
I also read that I need to add the binding into the “addons.cfg” file found at /etc/openhab2/services…
but I have no idea what to type if I uncomment the #bindings= line.
So I’m stuck and need some more help. THANK YOU so much.
Dave
