[SOLVED] Need help on OH2 with postupdate rule
Hi i am running OH2 in Win 10.
I have a rule that updates the value of a item.
The Rule seems to be working but the value changes back immediately.
items is
Number Aquara_Press_Wohn "Luftdruck. Wohn. [%.2f hPa]" {channel="mihome:sensor_weather_v1:158d0002c78578:pressure"}
and the Rule
rule "kpa in Hpa"
   		 Item Aquara_Press_Wohn received update
			var Number hpa = Aquara_Press_Wohn.state as DecimalType*10
    		Aquara_Press_Wohn.postUpdate(hpa)
			logInfo("Rulesxxxxxxxxxxxxx", "Aquara_Press_Wohn value updated to: "+ hpa)
logs generates this output
14:15:25.461 [INFO ] [smarthome.event.ItemStateChangedEvent] - Aquara_Hum_Wohn changed from 38.49 to 38.59
14:15:25.461 [INFO ] [thome.model.script.Rulesxxxxxxxxxxxxx] - Aquara_Press_Wohn value updated to: 998.10
14:15:25.461 [INFO ] [smarthome.event.ItemStateChangedEvent] - Aquara_Press_Wohn changed from 99.81 to 998.10
14:15:25.496 [INFO ] [smarthome.event.ItemStateChangedEvent] - Aquara_Press_Schlaf changed from 99.81 to 99.84
14:15:25.496 [INFO ] [smarthome.event.ItemStateChangedEvent] - mihome_sensor_weather_v1_158d0002c78578_pressure changed
Can someone plese help?
Basically you can’t do that.
The items reverts immediately because it gets updated by the device
What you need is another item:
Number Aquara_Press_Wohn "Luftdruck. Wohn. [%.2f kPa]" {channel="mihome:sensor_weather_v1:158d0002c78578:pressure"}
Number Aquara_Press_Wohn_hPa "Luftdruck. Wohn. [%.2f hPa]"
And then the rule is:
rule "kpa in Hpa"
    var Number hpa = (Aquara_Press_Wohn.state as Number) * 10
    Aquara_Press_Wohn_hPa.postUpdate(hpa)
    logInfo("Rulesxxxxxxxxxxxxx", "Aquara_Press_Wohn value updated to: " + hpa)
OK. It was a logic error .
Thanks for the hint.
It worked perfectly.
Thank you very much
