Hi i am Using OH2 on Win10
I try to send a Number value to an item created from String
The problem is that the new Item does not accept my value
What i am doing wrong?
Triggering Items is for example (I have several Items called: Sonoff_xxx_xxx)
Number Sonoff_TV_Today "Energie heute [%.3f kWh]" <energy> (gkwD) { channel="mqtt:topic:f52cfe9a:eToday" }
and i would like to send the value price to a new item created by rule.
The name of the new Item is already set in my items as:
Number Stromkosten_TV_Today "Stromkosten Heute[%.3f €]" <piggybank>
Here is my rule
rule "Update Stromkosten" //Berechnet Stromkosten für jedes Mitglied
Member of gkwD received update
var Number price = (triggeringItem.state as Number) * strompreis // strompreis is declared as val strompreis=0.26
val membername = triggeringItem.name.split("_").get(1) //Schlaf, TV, Trock, etc.
var ending = triggeringItem.name.split("_").get(2) //Today, etc.
var newItemName = ("Stromkosten_"+membername+"_"+ending)
logInfo("Stromkosten", "Result Price:" + price)
logInfo("Stromkosten", "Result membername:" + membername)
logInfo("Stromkosten", "Result ending:" + ending)
logInfo("Stromkosten", "Result itemName:" + newItemName +" "+triggeringItem.state+" "+triggeringItem.name)
sendCommand(newItemName, price)
Logs seem to be ok except the sendCommand
2019-09-25 12:46:23.188 [INFO ] [e.smarthome.model.script.Stromkosten] - Result Price:0.00390
2019-09-25 12:46:23.189 [INFO ] [e.smarthome.model.script.Stromkosten] - Result membername:TV
2019-09-25 12:46:23.191 [INFO ] [e.smarthome.model.script.Stromkosten] - Result ending:Today
2019-09-25 12:46:23.192 [INFO ] [e.smarthome.model.script.Stromkosten] - Result itemName:Stromkosten_TV_Today 0.015 Sonoff_TV_Today
2019-09-25 12:46:23.193 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Update Stromkosten': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(java.lang.String,java.lang.String) on instance: null
Could you help me to solve my problem?
Thank you
