I’m getting an error that logs a ton of error messages in the openhab.log file. Below is small portion of the log file starting a little before the start of the issue in today’s log file. How do I go about identifying what is causing the problem. It looks like it is happening in a rule called “George Leaving” based on what I see in the log, but it didn’t happen on a prior time executing that rule. There is some if logic in it so there may have been different conditions thus different paths of program flow. I plan on throwing in a bunch of logInfo() commands to see exactly where it’s going south. Besides that what can I do? I haven’t launched using debug yet as I can’t reproduce the issue on demand, and I was afraid the logs would really get out of control.
399460 [Peggy Leaving] INFO org.openhab.model.script.Leaving - Peggy Leaving
399468 [Peggy Arriving] INFO org.openhab.model.script.Arriving - Peggy Arriving
400468 [Peggy Leaving] INFO org.openhab.io.net.exec.ExecUtil - executed commandLine 'espeak -v en-north -p 25 -s 100 Lets-save-some-money'
401675 [George Leaving] INFO org.openhab.model.script.Leaving - George Leaving
401682 [George Arriving] INFO org.openhab.model.script.Arriving - George Arriving
402688 [George Leaving] INFO org.openhab.io.net.exec.ExecUtil - executed commandLine 'espeak -v en-north -p 25 -s 100 Lets-save-some-money'
1231561 [Update max and min temperatures] INFO org.openhab.model.script.Weather - Temperature evolved of null degrees.
1265192 [EventThread] INFO o.o.i.myopenhab.internal.MyOHClient - Connected to my.openHAB service (UUID = 9862538c-f14d-446f-837a-a9cce68eb5fd, base URL = http://localhost:8080)
1827215 [Ecobee Refresh Service] WARN org.openhab.io.net.http.HttpUtil - Method failed: HTTP/1.1 500 Internal Server Error
4145641 [George Leaving] INFO org.openhab.model.script.Leaving - George Leaving
4180230 [qtp36138742-1356] ERROR c.s.j.s.container.ContainerResponse - The RuntimeException could not be mapped to a response, re-throwing to the HTTP container
org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException: index=21, size=4
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:346) ~[org.eclipse.emf.common_2.8.0.v20130125-0546.jar:na]
at org.openhab.ui.internal.items.ItemUIRegistryImpl.getWidget(ItemUIRegistryImpl.java:461) ~[na:na]
at org.openhab.io.rest.internal.listeners.SitemapStateChangeListener.getRelevantItemNames(SitemapStateChangeListener.java:96) ~[na:na]
at org.openhab.io.rest.internal.listeners.ResourceStateChangeListener.registerStateChangeListenerOnRelevantItems(ResourceStateChangeListener.java:183) ~[na:na]
at org.openhab.io.rest.internal.listeners.ResourceStateChangeListener.registerItems(ResourceStateChangeListener.java:166) ~[na:na]
at org.openhab.io.rest.internal.broadcaster.GeneralBroadcaster.addStateChangeListener(GeneralBroadcaster.java:68) ~[na:na]
at org.openhab.io.rest.internal.resources.SitemapResource.getPageData(SitemapResource.java:164) ~[na:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.7.0_79]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) ~[na:1.7.0_79]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.7.0_79]
at java.lang.reflect.Method.invoke(Method.java:606) ~[na:1.7.0_79]
at com.sun.jersey.spi.container.JavaMethodInvokerFactory$1.invoke(JavaMethodInvokerFactory.java:60) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.model.method.dispatch.AbstractResourceMethodDispatchProvider$JResponseOutInvoker._dispatch(AbstractResourceMethodDispatchProvider.java:236) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.model.method.dispatch.ResourceJavaMethodDispatcher.dispatch(ResourceJavaMethodDispatcher.java:75) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.uri.rules.HttpMethodRule.accept(HttpMethodRule.java:302) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.uri.rules.RightHandPathRule.accept(RightHandPathRule.java:147) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.uri.rules.ResourceClassRule.accept(ResourceClassRule.java:108) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.uri.rules.RootResourceClassesRule.accept(RootResourceClassesRule.java:84) ~[jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1542) [jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1473) [jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1419) [jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1409) [jersey-server-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:409) [jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:540) [jersey-servlet-1.18.1.jar:1.18.1]
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:715) [jersey-servlet-1.18.1.jar:1.18.1]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848) [javax.servlet_3.0.0.v201112011016.jar:na]
at org.atmosphere.util.AtmosphereFilterChain.doFilter(AtmosphereFilterChain.java:135) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.util.AtmosphereFilterChain.invokeFilterChain(AtmosphereFilterChain.java:96) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.handler.ReflectorServletProcessor$FilterChainServletWrapper.service(ReflectorServletProcessor.java:317) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.handler.ReflectorServletProcessor.onRequest(ReflectorServletProcessor.java:160) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AsynchronousProcessor.action(AsynchronousProcessor.java:206) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AsynchronousProcessor.suspended(AsynchronousProcessor.java:105) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.container.Jetty7CometSupport.service(Jetty7CometSupport.java:57) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.container.JettyAsyncSupportWithWebSocket.service(JettyAsyncSupportWithWebSocket.java:67) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereFramework.doCometSupport(AtmosphereFramework.java:2076) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereServlet.doPost(AtmosphereServlet.java:211) [atmosphere-runtime-2.2.5.jar:2.2.5]
at org.atmosphere.cpr.AtmosphereServlet.doGet(AtmosphereServlet.java:197) [atmosphere-runtime-2.2.5.jar:2.2.5]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735) [javax.servlet_3.0.0.v201112011016.jar:na]
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:68) [org.eclipse.equinox.http.servlet_1.1.300.v20120522-1841.jar:na]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413) [org.eclipse.jetty.servlet_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.Server.handle(Server.java:350) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:890) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:944) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:630) [org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230) [org.eclipse.jetty.http_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606) [org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46) [org.eclipse.jetty.io_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at java.lang.Thread.run(Thread.java:745) [na:1.7.0_79]
4180233 [qtp36138742-1356] ERROR o.a.h.ReflectorServletProcessor - onRequest()
