I use openHAB 2.4 stable with an AeoTec Z-Stick Gen 5 and a Neo Wallplug (NAS-WR01ZE). The Z-Wave sticks works fine, but after I added the wallplug it is only shown as Unknown Device
Hi, Chris. Sorry for disturbing youm but I also have a problem with this device. It’s detected by binding, channels are detected as well, but configuration isn’t available. I use Openhab 2.5.0 release from last weekend with all updated bindings, device was bought and first time included today.
I attached screenshots with device information and configuration page.
Also, i tried next: remove thing and add it once more, clean the cache - problem still is present.
This helped me with another device, door/window sensor, which i added a long time ago, but not with this new plug.
As I wrote in my post, I removed and added the thing without any result. I also removed device from network and included it again without security and like new nodeId - also no configuration. BTW, I noticed that device manual also didn’t appeared on page.
The one more problem with this device is present.
Please, see attached screen - Electric_KWH is reported twice, once with -2… value, and once with voltage value. It’s really strange.
Removed it’s xml file from /var/lib/openhab2/zwave/
Restarted openhab
Added device again through inbox in paperUI
dbReference is still 1117, pointing to deleted device in database.
BTW, the release version of zwave binding had place 4 days ago - i don’t see any changes since that time, which can result in this issue. From my point of view, the possible solution will be to somehow corrupt this device in database (f.e., set non-existing manufacture, device id etc…).
And, one more, binding shows me 4 such devices, while in device database only 2 are active.
Still the same Cache was cleaned using openhab-cli, then i manually checked the content of /var/lib/openhab/ - no cache or tmp directories exists, directory .cache also was empty.
Started openhab2 again, removed added device and again that 1117 without config.
2019-12-19 17:03:59.515 [hingStatusInfoChangedEvent] - ‘zwave:device:7e178d6a:node6’ changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2019-12-19 17:04:28.716 [hingStatusInfoChangedEvent] - ‘zwave:device:7e178d6a:node6’ changed from ONLINE to REMOVING
2019-12-19 17:04:28.732 [hingStatusInfoChangedEvent] - ‘zwave:device:7e178d6a:node6’ changed from REMOVING to REMOVED
2019-12-19 17:04:28.758 [hingStatusInfoChangedEvent] - ‘zwave:device:7e178d6a:node6’ changed from REMOVED to UNINITIALIZED
2019-12-19 17:04:28.924 [hingStatusInfoChangedEvent] - ‘zwave:device:7e178d6a:node6’ changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-12-19 17:04:54.720 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘co2_notification’: Could not cast NULL to java.lang.Number; line 23, column 44, length 32
2019-12-19 17:05:01.905 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:7e178d6a:node6’ to inbox.
2019-12-19 17:05:01.908 [home.event.InboxAddedEvent] - Discovery Result with UID ‘zwave:device:7e178d6a:node6’ has been added.
2019-12-19 17:05:08.184 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘zwave:device:7e178d6a:node6’ has been removed.
2019-12-19 17:05:08.208 [hingStatusInfoChangedEvent] - ‘zwave:device:7e178d6a:node6’ changed from UNINITIALIZED to INITIALIZING
2019-12-19 17:05:08.241 [hingStatusInfoChangedEvent] - ‘zwave:device:7e178d6a:node6’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2019-12-19 17:05:08.243 [hingStatusInfoChangedEvent] - ‘zwave:device:7e178d6a:node6’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2019-12-19 17:05:08.251 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:7e178d6a:node6’ has been updated.
2019-12-19 17:05:08.309 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:7e178d6a:node6’ has been updated.
2019-12-19 17:05:08.320 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:7e178d6a:node6’ has been updated.
2019-12-19 17:05:08.327 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:7e178d6a:node6’ has been updated.
2019-12-19 17:05:08.346 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=]
