I just upgraded to OH 2.4, and using the NEST API 2.4.0 (firmware 5.9.3-6). I have a simple site map configured to see and set the temperature of a thermostat.
Text item=HallwayThermostat_Temperature label="Current Temperature [%.0f °F]" icon="temperature"
Setpoint item=HallwayThermostat_SetPoint label="Set Temperature [%.0f °F]" icon="temperature" minValue=65 maxValue=80 step=1
The thermostat is set to Fahrenheit, and when changing the temperature at the NEST unit, OpenHAB is updated correctly.
2018-12-28 10:01:41.146 [vent.ItemStateChangedEvent] - HallwayThermostat_Temperature changed from 74.0 to 75.0
2018-12-28 10:27:17.156 [vent.ItemStateChangedEvent] - HallwayThermostat_Temperature changed from 75.0 to 74.0
However, when I try to set the temperature from OpenHAB, I see the below messages in openhap.log.`
2018-12-28 09:58:47.399 [WARN ] [t.internal.handler.NestBridgeHandler] - Nest API error: Temperature F value is too high: 166.0
2018-12-28 09:58:50.080 [WARN ] [t.internal.handler.NestBridgeHandler] - Nest API error: Temperature F value is too high: 165.0
2018-12-28 09:59:10.337 [WARN ] [t.internal.handler.NestBridgeHandler] - Nest API error: Temperature F value is too high: 164.0
2018-12-28 09:59:13.057 [WARN ] [t.internal.handler.NestBridgeHandler] - Nest API error: Temperature F value is too high: 163.0
Apparently, the number is “converted”, as if I was trying to set the temperature in Celsius, and a value in Fahrenheit is sent. For instance, trying to set 74F, I see “value too high 165” in the log, as if I was trying to set 74C, which is 165.2F.
Or is it just something I configured incorrectly?
If I change everything to Celsius (thermostat, as well as OpenHAB configuration), it works perfectly.
Thank you in advance,
Miki.
