it’s my first post here I hope find help.
I install the binding Nest and all work fine I can change mode et get info, but I can’t set a setpoint temperature.
In log I find :[WARN ] [nding.nest.handler.NestBridgeHandler] - Nest API error: blocked
The API said ‘blocked’ my guess is you sent too many commands to Nest at the same time and they temp blocked you from using the API; give it an hour or two and you should be auto unblocked.
If you can set other aspects via the API from openhab, then you possibly have something misconfigured with the set point?
I think its a full block vs individual API call blocks, but I’m not sure I have my temps fully automated via rules and don’t have to mess with the set points, other then updating a global var in my rule.
