Using RPi3+
I made a mistake during preparation for a backup. I decided to reinstall the complete system.
Starting again with copying the IMG to the SD Card on my Win-PC.
(openhabianpi-raspbian-201804031720-gitdba76f6-crc9e93c3eb.img)
Something went wrong and I don’t know where and why.
See below.
I can stop the boot process (even if it hangs) and start sudo config etc.
I updated the system, add ons, configured the PW, time zone, start trail-logs…
After rebooting the system hangs.
On the other hand the browser session with “http://192.168.xx.yy:8080/start/index” seems to work fine.
I don’t want to start to configure the things etc. before the system starts normally.
Looking forward for some hints !
Below the complete log during the start… until it hangs
Blockquote
login as: openhabian
openhabian@openhabianpi’s password:
Linux openHABianPi 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Jan 27 21:16:02 2019 from 192.168.188.35
Wi-Fi is disabled because the country is not set.
Use raspi-config to set the country before use.
Every 2,0s: cat /boot/first-boot.log openHABianPi: Sun Jan 27 22:03:38 2019
2018-03-13_22:53:49_UTC [openHABian] Starting the openHABian initial setup.
2018-03-13_22:53:49_UTC [openHABian] Storing configuration… OK
2018-03-13_22:53:49_UTC [openHABian] Changing default username and password… OK
2018-03-13_22:53:59_UTC [openHABian] Setting up Ethernet connection… OK
2018-03-13_22:53:59_UTC [openHABian] Ensuring network connectivity… OK
2018-03-13_22:53:59_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2019-01-27_16:08:48_UTC [openHABian] Updating repositories and upgrading installed packages… FAILED
2019-01-27_16:10:19_UTC [openHABian] Initial setup exiting with an error!
2019-01-27_17:58:35_UTC [openHABian] Starting the openHABian initial setup.
2019-01-27_17:58:35_UTC [openHABian] Storing configuration… OK
2019-01-27_17:58:35_UTC [openHABian] Changing default username and password… SKIPPED
2019-01-27_17:58:35_UTC [openHABian] Setting up Ethernet connection… OK
2019-01-27_17:58:35_UTC [openHABian] Ensuring network connectivity… OK
2019-01-27_17:58:35_UTC [openHABian] Waiting for dpkg/apt to get ready… 2019-01-27_18:00:47_UTC [openHABian] Starting the openHABian initial setup.
2019-01-27_18:00:47_UTC [openHABian] Storing configuration… OK
2019-01-27_18:00:47_UTC [openHABian] Changing default username and password… SKIPPED
2019-01-27_18:00:47_UTC [openHABian] Setting up Ethernet connection… OK
2019-01-27_18:00:47_UTC [openHABian] Ensuring network connectivity… OK
2019-01-27_18:00:47_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2019-01-27_18:06:57_UTC [openHABian] Updating repositories and upgrading installed packages… FAILED
2019-01-27_18:07:02_UTC [openHABian] Initial setup exiting with an error!
2019-01-27_18:36:40_UTC [openHABian] Starting the openHABian initial setup.
2019-01-27_18:36:40_UTC [openHABian] Storing configuration… OK
2019-01-27_18:36:40_UTC [openHABian] Changing default username and password… SKIPPED
2019-01-27_18:36:40_UTC [openHABian] Setting up Ethernet connection… OK
2019-01-27_18:36:40_UTC [openHABian] Ensuring network connectivity… OK
2019-01-27_18:36:40_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2019-01-27_18:36:53_UTC [openHABian] Updating repositories and upgrading installed packages… FAILED
2019-01-27_18:39:27_UTC [openHABian] Initial setup exiting with an error!
2019-01-27_18:48:09_UTC [openHABian] Starting the openHABian initial setup.
2019-01-27_18:48:09_UTC [openHABian] Storing configuration… OK
2019-01-27_18:48:09_UTC [openHABian] Changing default username and password… SKIPPED
2019-01-27_18:48:09_UTC [openHABian] Setting up Ethernet connection… OK
2019-01-27_18:48:09_UTC [openHABian] Ensuring network connectivity… OK
2019-01-27_18:48:09_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2019-01-27_18:48:18_UTC [openHABian] Updating repositories and upgrading installed packages… OK
2019-01-27_18:53:37_UTC [openHABian] Installing git package… OK
2019-01-27_18:54:41_UTC [openHABian] Cloning myself… OK
2019-01-27_18:54:54_UTC [openHABian] Executing ‘openhabian-setup.sh unattended’…
2019-01-27_18:54:54_UTC [openHABian] Checking for root privileges… OK
2019-01-27_18:54:54_UTC [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2019-01-27_18:54:54_UTC [openHABian] Setting timezone based on IP geolocation… FAILED (pip)
2019-01-27_18:56:22_UTC [openHABian] Setting locale based on openhabian.conf… OK
2019-01-27_18:56:49_UTC [openHABian] Setting hostname of the base system… OK
2019-01-27_18:56:50_UTC [openHABian] Setting the GPU memory split down to 16MB for headless system… OK
2019-01-27_18:56:50_UTC [openHABian] Enabling Audio output… OK
2019-01-27_18:56:50_UTC [openHABian] Installing basic can’t-be-wrong packages (screen, vim, …)… OK
2019-01-27_18:57:55_UTC [openHABian] Installing additional needed packages… OK
2019-01-27_18:58:13_UTC [openHABian] Installing additional bluetooth packages… OK
2019-01-27_18:58:25_UTC [openHABian] Adding slightly tuned bash config files to system… OK
2019-01-27_18:58:25_UTC [openHABian] Adding slightly tuned vim config file to system… OK
