In the new Mail binding I got everything up and working with GMail. One thing I couldnt find is how could I add a custom sender name in the mail which is sent by openHAB?
Like now it only shows the mail address in the From header, with the old Mail Action I was able to add something like “openHAB server”.
SMTP server password: your gmail address or, if you have two-factor authentication set up (if not stop what you are doing and go set that up now!) an App password (search Google for tutorials)
Server port: 587 // this field is under “SHOW MORE”
thx for posting the settings.
even though my settings were originally the same as you posted, I recreated my mail thing
confirmed all settings and created a new app password. Maybe i got something wrong on the password or had a typo anywhere in my config i don’t know but now it’s working as intended
Exactly what it is saying: a cipher suite that is considered as weak is enabled. Probably we can disable it but that might lead to handshake problems, depending on the other side. If if occurs too often and spams your log I would set the log level of that class to error.
I have tried setting the log level of the Mail binding to ERROR but these warnings still can be seen. Which other packages should be set to ERROR only?
No I’m not 100% sure. This only started to appear after I have upgraded to 2.5M2 and I immeadiately setup the new Mail binding (no other new bindings installed/replaced).
So it might be the mail binding or something changed in the openhab core (?)
