Hi guys,
Good work with the new Mqtt binding, i’ve got most of it working apart from my 4 channel relay only has the first Power1 item/thing thats works?
sonoff.items
Switch MasterBed_Switch1 "Switch1" <light> (MasterBedTemp) ["Lighting"] { channel="mqtt:topic:mosquitto:masterbednode:power1" }
Switch MasterBed_Switch2 "Switch2" <light> (MasterBedTemp) ["Lighting"] { channel="mqtt:topic:mosquitto:masterbednode:power2" }
Switch MasterBed_Switch3 "Switch3" <light> (MasterBedTemp) ["Lighting"] { channel="mqtt:topic:mosquitto:masterbednode:power3" }
Switch MasterBed_Switch4 "Switch4" <light> (MasterBedTemp) ["Lighting"] { channel="mqtt:topic:mosquitto:masterbednode:power4" }
String MasterBed_Reachable "Status [%s]" <network-on> (MasterBedTemp) { channel="mqtt:topic:mosquitto:masterbednode:reachable" }
Number MasterBed_Temperature "Temperature[%.2s °C]" <temperature> (MasterBedTemp) { channel="mqtt:topic:mosquitto:masterbednode:temperature" }
Number MasterBed_Humidity "Humidity[%d %%]" <humidity> (MasterBedTemp) { channel="mqtt:topic:mosquitto:masterbednode:humidity" }
Number MasterBed_Wifi "WIFI Signal[%d %%]" <qualityofservice> (MasterBedTemp) { channel="mqtt:topic:mosquitto:masterbednode:rssi" }
String MasterBed_version "Sonoff Version: [%s]" <sonoff_basic> (MasterBedTemp) { channel="mqtt:topic:mosquitto:masterbednode:Version"}
sonoff.things
Bridge mqtt:broker:mosquitto "mosquitto" @ "MQTT" [ host="xxxxxxxx", port=1883, secure=false, retain=false, username="openhabian", password="xxxxxxxxxx", qos=0, keep_alive_time=30000, reconnect_time=60000 ]
// Sonoffs
Thing topic masterbednode "MasterBed" @ "MQTT" {
Channels:
Type switch : power "Power1" [stateTopic="stat/masterbednode/POWER1", commandTopic="cmnd/masterbednode/POWER1", on="ON", off="OFF"]
Type switch : power "Power2" [stateTopic="stat/masterbednode/POWER2", commandTopic="cmnd/masterbednode/POWER2", on="ON", off="OFF"]
Type switch : power "Power3" [stateTopic="stat/masterbednode/POWER3", commandTopic="cmnd/masterbednode/POWER3", on="ON", off="OFF"]
Type switch : power "Power4" [stateTopic="stat/masterbednode/POWER4", commandTopic="cmnd/masterbednode/POWER4", on="ON", off="OFF"]
Type string : reachable "Reachable" [ stateTopic="tele/masterbednode/LWT" ]
Type number : temperature "Temperature" [ stateTopic="tele/masterbednode/SENSOR", transformationPattern="JSONPATH:$.SI7021.Temperature"]
Type number : humidity "Humidity" [ stateTopic="tele/masterbednode/SENSOR", transformationPattern="JSONPATH:$.SI7021.Humidity"]
Type number : rssi "WiFi Signal Strength" [ stateTopic="tele/masterbednode/STATE", transformationPattern="JSONPATH:$.Wifi.RSSI"]
Type string : Version "Firmware" [stateTopic="stat/masterbednode/STATUS2", transformationPattern="JSONPATH:$.StatusFWR.Version"]
Power2,3 and 4 arent showing??
any help will be appreciated
cheers
