Hi, during our last power failure 2 weeks ago my microSD card got corrupted with my complete Openhabian software. The SD card is no longer usable. So I bought a new card and would like to install my old image. I created an image with openahabian 1.4.1 which works. I can copy my backup files (items, sitemap, etc.) but they does not work because my old image was created with knx binding 1… This means I have to use an old openhabianpi 1.4 or older. But when I try the old version my Pi does not install correctly. I always get the same error message. I think this is because I do not use the latest version. My question is if I can use the latest 1.4.1 with an old KNX binding or is there a way to update my code from knx bindng 1… to the current version 2… Please help.
I get everytime different error messages. git package, Zulu embedded, cloning myslef, etc.
Ok to get up and running with old configs you can enable legacy bindings
(PaperUI->Configuration->System->Include Legacy 1.x Bindings)
You should be able to use the newest stable build to run them on. You can run both bindings at the same time and move them over when you have the time.
Thanks for the hint. I will try and let you know if it works.
You made my day. Thanks it does work again. Only one thing is not working. The charts does not show anything. I will wait till tomorrow and give it another try. Maybe this is why it is not working anymore.
Configuration model ‘rrd4j.persist’ has errors, therefore ignoring it: [1,1]: mismatched input ‘’ expecting ‘Strategies’
That would stop charts from using that database, no matter how long you wait. You might share that file, if you cannot see what is wrong with it.
This is it.
// persistence strategies have a name and a definition and are referred to in the “Items” section Strategies
// for rrd charts, we need a cron strategy
everyMinute : “0 * * * * ?”
every5Minutes : “0 0/5 * * * ?”
default = everyMinute, every5Minutes
Items
WS_Aussentemperatur, WS_Wind_km : strategy = everyMinute, restoreOnStartup
Helligkeit, Sonnenstand_Azimut, Fassade_1_Position, Fassade_2_Position, Fassade_3_Position, Fassade_4_Position : strategy = everyMinute, restoreOnStartup
//gChartTempWind* : strategy = everyMinute, restoreOnStartup
RTR_Buero_Ist_Temperatur, RTR_Buero_Soll_RM_Temperatur, RTR_Buero_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_BadKinder_Ist_Temperatur, RTR_BadKinder_Soll_RM_Temperatur, RTR_BadKinder_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_GZimmer_Ist_Temperatur, RTR_GZimmer_Soll_RM_Temperatur, RTR_GZimmer_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_Kind2_Ist_Temperatur, RTR_Kind2_Soll_RM_Temperatur, RTR_Kind2_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_Kind1_Ist_Temperatur, RTR_Kind1_Soll_RM_Temperatur, RTR_Kind1_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_FlurAltbau_Ist_Temperatur, RTR_FlurAltbau_Soll_RM_Temperatur, RTR_FlurAltbau_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_FlurNeubau_Ist_Temperatur, RTR_FlurNeuban_Soll_RM_Temperatur, RTR_FlurNeubau_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_BadEltern_Ist_Temperatur, RTR_BadEltern_Soll_RM_Temperatur, RTR_BadEltern_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_Schlafen_Ist_Temperatur, RTR_Schlafen_Soll_RM_Temperatur, RTR_Schlafen_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_Kino_Ist_Temperatur, RTR_Kino_Soll_RM_Temperatur, RTR_Kino_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_Wohnen_Ist_Temperatur, RTR_Wohnen_Soll_RM_Temperatur, RTR_Wohnen_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_Flur_Ist_Temperatur, RTR_Flur_Soll_RM_Temperatur, RTR_Flur_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_DG_Ist_Temperatur, RTR_DG_Soll_RM_Temperatur, RTR_DG_Stellgroesse : strategy = everyMinute, restoreOnStartup
RTR_Garage_Ist_Temperatur : strategy = everyMinute, restoreOnStartup
Please use code fences for inclusions like that, where format is important.
At a guess, trim out the blank lines
Sorry I don’t get it. Original code looks like this and it worked before my crash of the SD card w/o any problem. Forgot to insert it in code style for better understanding.
// persistence strategies have a name and a definition and are referred to in the "Items" section
Strategies
everyMinute : "0 * * * * ?"
every5Minutes : "0 0/5 * * * ?"
Items
There are occasional posts with very similar issues. They seem to revolve around the xxx.persist file parser being quite picky about hidden control characters.
I note that the unfenced post of your file shows no blank line between
every5Minutes : “0 0/5 * * * ?” default = everyMinute, every5Minutes
but the code fenced version does - that’s suspicious.
Probably the most sure-fire fix -
Tried it w/o reboot of the system. Does not work. Do you think I should reboot?
This is what I get when I try to open a chart.
[WARN ] [thome.ui.internal.chart.ChartServlet] - Chart generation failed: null
I tried it again with a restart of the system. Created a new file (Texteditior) Copied the code from the old to the new file and renamed it. Copied the file to the Pi and restart the system. No change. Does not work.
You’re still getting this error, then?
With copy and paste or did you retype it? If you just selected and copied and pasted than any stray character that may have been causing problems would still be there.
I opened a new text file and copied everything from the original file. I took windows text document because it does not contain any format of the text. After that I renamed it and copied it to the Pi.
That was probably not sufficient. If there were any hidden characters, they likely survived the copy and paste.
Note this warning
Thanks for the hint. I have another idea. Could it be possible that the sitemap chart function does not work because of the failure I got.
“Chart generation failed: null”
This is my sitemap code. Maybe I was looking into the wrong direction.
Text item=RTR_Garage_Ist_Temperatur label="Garage [%.1f °C]" valuecolor=[>=25="red",>23="orange",>22="yellow",>20="lime",>18="aqua",<=18="navy"]
Switch item=Room_Temperature_Chart label="Ist/Soll-Temperatur" icon="temperature" mappings=[0="Day", 1="3 Days", 2="Week", 3="Month"]
Chart item=RTR_Garage_Ist_Temperatur period=D refresh=600000 visibility=[Room_Temperature_Chart==0, Room_Temperature_Chart=="NULL"]
Chart item=RTR_Garage_Ist_Temperatur period=3D refresh=3600000 visibility=[Room_Temperature_Chart==1]
Chart item=RTR_Garage_Ist_Temperatur period=W refresh=36000000 visibility=[Room_Temperature_Chart==2]
Chart item=RTR_Garage_Ist_Temperatur period=M refresh=36000000 visibility=[Room_Temperature_Chart==3]
Has anybody an idea? Can somebody tell me where I can see if rrd4j.persist is recording or not? Please help. Thanks.
You can query the database through the OH REST API Docs. You can install the docs from the UI tab in PaperUI. Go down to the persistence section and it should be self explanatory what to do from there. If you perform a query on your Item and get nothing back you will know it’s not being saved.
Sorry but I haven’t used that before. I just clicked on “Try it out”. Below is the result. I do not know what to do to be honest.
Response Class (Status 200)
"string"
Response Content Type
Parameters
Parameter | Value | Description | Parameter Type | Data Type |
serviceId | Id of the persistence service. If not provided the default service will be used | query | string |
Curl
curl -X GET --header “Accept: application/json” “http://openhabianpi:8080/rest/persistence/items”
Request URL
Response Body
Response Code
200
Response Headers
“content-length”: “2”,
“content-type”: “application/json”,
“server”: “Jetty(9.4.11.v20180605)”
