Hey there,
i´m running into big trouble clearing the caches. What i did is trying to clear the cache like this. After that my system won´t start anymore.
openhab-cli stop
openhab-cli clean-cache
openhab-cli start
From that point i wasn´t able to start the service openhabian again.
When i do:
sudo openhab-cli start i will get this:
The System want´s to start but the start fails
i´m also unable to reach to the console. trying this, i get this error:
i´m a noob in linux systems and i´m breaking my head with this. it would by very greatful if someone can put me on the right way.
I’m using RPI same as the OP and have always used the trailing .service for stopping and starting. I just checked if using the command without .service would stop/start OH and it does.
So now I have to ask, other than being 8 key strokes shorter, what’s the difference between the two?
Please mark the post solved by clicking the square box (bottom right corner) on the post that provided the solution. Also edit the title, add [Solved] to the beginning, this will help others with similar issues find a quick solution.
