[SOLVED] No Connection to openhabian after clearing cache
(Bernd Grimm) #1
  • Platform information:
    • Hardware: _RaspberryPi3b
    • OS: _Openhabian
    • openHAB version:2
Hey there,
i´m running into big trouble clearing the caches. What i did is trying to clear the cache like this. After that my system won´t start anymore.
  • openhab-cli stop
  • openhab-cli clean-cache
  • openhab-cli start
From that point i wasn´t able to start the service openhabian again.
When i do:
sudo openhab-cli start i will get this:
40
The System want´s to start but the start fails
i´m also unable to reach to the console. trying this, i get this error:
09
i´m a noob in linux systems and i´m breaking my head with this. it would by very greatful if someone can put me on the right way.
(Udo Hartmann) #3
Please do not use openhab-cli start but
sudo systemctl start openhab2.service
as openHAB should be started as a service when using GNU/Linux.
(Bernd Grimm) #4
Thanks Udo,
i tried this…getting this20
nothing happens after that - the log stay emtpy
(Udo Hartmann) #5
What do you get when typing
systemctl status openhab2.service
(Bernd Grimm) #6
(Udo Hartmann) #7
Myabe retry to use
(Bernd Grimm) #8
ok thanks - i will try and give feedback - many thanks!!!
(CM6.5 H102) #9
@bernd1109 if the above doesn’t work try:
sudo systemctl stop openhab2.service
sudo openhab-cli clean-cache
sudo reboot
Sometimes a reboot, opposed to just a restart, will fix the issue.
Best of Luck
(Miika Jukka) #10
FYI, when you are using systemd to control your services you can leave out the trailing .service:
sudo systemctl [stop|start|restart|status] openhab2
(CM6.5 H102) #11
I’m using RPI same as the OP and have always used the trailing .service for stopping and starting. I just checked if using the command without .service would stop/start OH and it does.
So now I have to ask, other than being 8 key strokes shorter, what’s the difference between the two?
(Miika Jukka) #12
There’s no other difference that I know. Just a shortcut built in systemd service handling.
(CM6.5 H102) #13
@gitMiguel My slow typing fingers would like to say thank you.:joy: Anytime I learn something new is good but even better when the result is less typing.:grinning:
(Bernd Grimm) #14
Thanks to all for this quit support - it seems to work again.
Have a great weekend!
(CM6.5 H102) #15
@bernd1109 Glad you got it working.:+1:
Please mark the post solved by clicking the square box (bottom right corner) on the post that provided the solution. Also edit the title, add [Solved] to the beginning, this will help others with similar issues find a quick solution.
(openHAB beginner) #16
Ran into this issue as well, this did the trick!
Thank you
