As title says. There are no panels on my habpanel if I get through cloud. No matter if it’s from browser or from Android app. It just prompts me the “tutorial” to start creating panels.
You should be able to see your server saved panels when connecting remote via the android app. Did you try to select the server saved panel configuration?
The same should be working when connecting via myopenhab on the browser!
On both ways the selection of the server based config has to be done separately.
Found it, thank you very much. Now the panel size it’s not scaled well for mobile. Well I guess I will do another panel sized for mobile
