# \[SOLVED\] No switch button in BasicUI
**URL:** <https://community.openhab.org/t/solved-no-switch-button-in-basicui/38323>\
**Category:** Installation\
**Created:** [January 5, 2018, 10:59pm UTC](https://community.openhab.org/t/solved-no-switch-button-in-basicui/38323 "2018-01-05T22:59:20Z")\
**Posts on this page:** 1\
**Showing post:** 5
<div class="post-metadata">
**Author:** ![Josar](https://community.openhab.org/user_avatar/community.openhab.org/josar/32/13357_2.png) [@Josar](https://community.openhab.org/u/Josar)\
**Post date:** [January 6, 2018, 2:07am UTC](https://community.openhab.org/t/solved-no-switch-button-in-basicui/38323/5 "2018-01-06T02:07:11Z")
</div>
@Trainer I might be wrong but I think you use openhab 1 syntax.
Have a look here for openhab 2 syntax and a basic tutorial how to use the exec binding.
> [@OpenHAB Exec Binding explained in detail on 433MHz radio transmitter example](https://community.openhab.org/t/1-openhab-433mhz-radio-transmitter-tutorial-exec-binding-explained-in-detail/34977):
> This is a example thread to show how the exec binding 2.x works with detailed explanations. This tutorial only works since openHAB 2.3.0 Build #1212. I set up a fresh installation of “Raspbian GNU/Linux 9 (stretch)” and installed [OpenHAB](http://docs.openhab.org/installation/linux.html) just followed my own [thread](https://community.openhab.org/t/openhab2-exec-binding/27819/17) and found some more information i missed at the first time. It is based on the Tutorial from [here](http://www.forwardme.de/2016/11/24/433mhz-funksteckdosen-mit-raspberry-pi-und-openhab-schalten/). First make sure you connect your transmitter with the Raspberry like follows. Have a look at the [RPI pinout](https://de.pinout.xyz/#). Pin ATAD Data to 11 - …
Read the whole thread as there is a lot guidance to find there. Maybe this helps.
Please use code fences for your code.
```auto
Code goes here
Use the buttons over the text entry field for that.
_[View the full topic](https://community.openhab.org/t/solved-no-switch-button-in-basicui/38323)._
