Hey Guys,
i dont have a things file in my default /etc/openhab2/things.
Though i have loads of things
Is there perhaps a different file location that i can find this please?
Hey Guys,
Did you setup your things through PaperUI. If yes, the things are not stored in that folder. Thatβs true for items/rules also which are made through PaperUI
thx for the reply.
That is correct, these are setup via the UI.
Where can i find the correct file please?
Got 1 thing i can not delete via the UI.
error 409 Conflict
2018-10-20 13:18:28.523 [INFO ] [st.core.internal.thing.ThingResource] - Received HTTP DELETE request for update at 'things/ipcamera:ONVIF:001' for an unmanaged thing 'ipcamera:ONVIF:001'.
Thx
All config data are stored in a json database, the docs (see above) can tell you more. But be warned, if this file gets corrupted you likely need to start over from scratch.
thx for the reply and warning.
