Hello everybody. I’m trying to leach Node-Red for a few days now. I have re-installed Openhabian 1.5 on Raspberry Pi 3 and 4. Everything looks so far normal. Node-Red installed from Openhabian config and get no errors. Node Red is not displayed on the web interface. When I go directly over port 1880, Node-Red seems to be running normally.
In version 1.4 everything was still displayed in the web interface.
Best regards
Axel
Welcome to the openHAB Community
Addon to add external links to openHAB dashboard
tl;dr
create dashboard.cfg
in /etc/openhab2/services/
Add your custom services (read above topic link)
frontail.link-name=openHAB Log Viewer
frontail.link-url=http://home:9001
frontail.link-imageurl=../static/frontail.png
nodered.link-name=Node-RED
nodered.link-url=http://home:1880
nodered.link-imageurl=../static/nodered.png
grafana.link-name=Grafana
grafana.link-url=http://home:3000
grafana.link-imageurl=../static/grafana.png
Thanks for the quick answer and help.
But why was it automatically displayed in the old version and not anymore?
Best regards
Hey there @Axel_Koeneke please keep it englisch since this is an international community
Why this happened? No clue. Would have to look up the changelog of openhabian.
Ups… Sorry
I will test it later and report.
It will work I tested it local before posting.
Just be sure to replace “home” in the example with your openHAB IP
It seems to work, but Node-Red does not start automatically anymore. I had to start manually after starting up the Raspberry with “node-red-start”. Also that used to be automatic in version 1.4.
Best regards
sudo systemctl enable node-red.service
or what ever the name of the service is
so far so good. Now only the image is missing, but that does not bother me now.
The missing image is because you did not read
This part
Of course I read everything, but I first had to familiarize myself with Imgur’s page because of the pictures.
Now it looks good.
Apparently, other users have recognized the problem.
See also: https://github.com/openhab/openhabian/issues/738
