I am newbie & tomorrow I successfully boot Openhab on RPI3.
Version:- Openhabian-v1-4-released/37398
After completion of Openhab installation I can open its console by typing >>IP of Pi:8080>> in web browsr & discover things successfully.
I also trying to open nodered by typing >>IP-of-Pi:1880>>. But not getting nodered running.
Do I have to install it by SSH client??? Or
do I have to start it from SSH client???
H102
(CM6.5 H102)
2
Use the openhabian config tool to add Node red.
From the command line use this:
sudo openhabian-config
After a new window opens do the following:
Move down and select Optional Components then Node Red (25)
Problem solved.
Followed documentation procedure is mentioning below URL
I ssh raspberry Pi from my laptopudo
Applied command :- openhabian-config
& Front install nodered & it’s working.
H102
(CM6.5 H102)
4
Glad to see you have it working.
Please click the square box on the post that provided the solution.
