The Nodon supports the scene activation class - I recall when adding the database that this was an option, so you need to switch to this setting.
Take a look here for information on scenes. Note that this was written a long tim back and the endpoints were 1 back then, so this will need to be removed. Otherwise, I think the information in this link should be applicable.
I removed the node8.xml file and I tried with the new build and got the following exception:
2015-10-12 08:18:31.254 [ERROR] [b.z.i.protocol.ZWaveController:1133]- Exception during Z-Wave thread: Input.
com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$UnknownFieldException: No such field org.openhab.binding.zwave.internal.config.ZWaveDbManufacturer.ConfigFile
---- Debugging information ----
field : ConfigFile
class : org.openhab.binding.zwave.internal.config.ZWaveDbManufacturer
required-type : org.openhab.binding.zwave.internal.config.ZWaveDbManufacturer
converter-type : com.thoughtworks.xstream.converters.reflection.ReflectionConverter
path : /Manufacturers/Manufacturer[56]/ConfigFile
line number : 2800
class[1] : org.openhab.binding.zwave.internal.config.ZWaveProductDatabase$ZWaveDbRoot
version : 1.4.6
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.handleUnknownField(AbstractReflectionConverter.java:495) ~[na:na]
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doUnmarshal(AbstractReflectionConverter.java:351) ~[na:na]
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshal(AbstractReflectionConverter.java:257) ~[na:na]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:72) ~[na:na]
at com.thoughtworks.xstream.core.AbstractReferenceUnmarshaller.convert(AbstractReferenceUnmarshaller.java:65) ~[na:na]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:66) ~[na:na]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:50) ~[na:na]
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doUnmarshal(AbstractReflectionConverter.java:426) ~[na:na]
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:134) ~[na:na]
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32) ~[na:na]
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1157) ~[na:na]
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1141) ~[na:na]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1021) ~[na:na]
at org.openhab.binding.zwave.internal.config.ZWaveProductDatabase.loadDatabase(ZWaveProductDatabase.java:92) ~[na:na]
at org.openhab.binding.zwave.internal.config.ZWaveProductDatabase.<init>(ZWaveProductDatabase.java:48) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeStageAdvancer.advanceNodeStage(ZWaveNodeStageAdvancer.java:535) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeStageAdvancer.ZWaveIncomingEvent(ZWaveNodeStageAdvancer.java:1037) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.notifyEventListeners(ZWaveController.java:598) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveWakeUpCommandClass.setAwake(ZWaveWakeUpCommandClass.java:416) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveWakeUpCommandClass.handleApplicationCommandRequest(ZWaveWakeUpCommandClass.java:186) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:80) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:221) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:194) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$6(ZWaveController.java:189) ~[na:na]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1126) ~[na:na]
2015-10-12 08:18:39.931 [TRACE] [veController$WatchDogTimerTask:1508]- Watchdog: Checking Serial threads
I checked line 2800 and it points to the config file. I also zipped the addon and used an online tool to validate the XML from nodon/crc3100.xml and it seems to be correct.
