Although I see a lot of red stuff flash past in the karaf log every RL test I do to the system works. Gonna download the logs and look a little more on what those red parts are saying.
2017-04-17 00:34:20.753 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
java.lang.IllegalStateException: Timer already cancelled.
at java.util.Timer.sched(Timer.java:397)[:1.8.0_121]
at java.util.Timer.schedule(Timer.java:193)[:1.8.0_121]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.startIdleTimer(ZWaveNodeInitStageAdvancer.java:1421)[207:org.openhab.binding.zwave:2.1.0.201704151452]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.advanceNodeStage(ZWaveNodeInitStageAdvancer.java:297)[207:org.openhab.binding.zwave:2.1.0.201704151452]
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.ZWaveIncomingEvent(ZWaveNodeInitStageAdvancer.java:1340)[207:org.openhab.binding.zwave:2.1.0.201704151452]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.notifyEventListeners(ZWaveController.java:567)[207:org.openhab.binding.zwave:2.1.0.201704151452]
at org.openhab.binding.zwave.internal.protocol.ZWaveNode.setNodeState(ZWaveNode.java:257)[207:org.openhab.binding.zwave:2.1.0.201704151452]
at org.openhab.binding.zwave.internal.protocol.serialmessage.ApplicationCommandMessageClass.handleRequest(ApplicationCommandMessageClass.java:46)[207:org.openhab.binding.zwave:2.1.0.201704151452]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingRequestMessage(ZWaveController.java:248)[207:org.openhab.binding.zwave:2.1.0.201704151452]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.handleIncomingMessage(ZWaveController.java:214)[207:org.openhab.binding.zwave:2.1.0.201704151452]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.access$7(ZWaveController.java:208)[207:org.openhab.binding.zwave:2.1.0.201704151452]
at org.openhab.binding.zwave.internal.protocol.ZWaveController$ZWaveInputThread.run(ZWaveController.java:1324)[207:org.openhab.binding.zwave:2.1.0.201704151452]
How about a reduced version - just delete the XML files and see if that works. Obviously you can’t do this, but others can try it and I can only think that the problem must have been related to the fix I’ve just merged.
The build I ran has completed although there are some test failures so I’m not sure if it’s used downstream. This might fix the problem - it’s the only thing I can think might have caused this.
I did controller remove, removed all things in karaf console, restarted OH2, deleted all XML files.
Recreated controller and things…
I have around 8 zwave devices, 50% of them still unknown… and I still see strange exceptions in the log… (“IllegalStateException timer already cancelled” this time)
hopefully it is just that network recreation takes some time?
I don’t know - the build of the binding is done already, but I don’t know when other packages downstream are rebuilt. I don’t know if packaged use the binding directly (in which case it should be available), or if it’s through something else.
I still get exceptions… now like these (looks like an endless loop somehow?)
2017-04-17 01:18:04.982 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Stage DYNAMIC_END. Initialisation retry timer triggered. Increased to 10000
2017-04-17 01:18:04.983 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Node advancer - DYNAMIC_END: queue length(0), free to send(true)
2017-04-17 01:18:04.983 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Initialisation retry timer started 10000
2017-04-17 01:18:04.984 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Node advancer: loop - DYNAMIC_END try 1: stageAdvanced(false)
2017-04-17 01:18:06.551 [ERROR] [ve.internal.protocol.ZWaveController] - Exception during ZWave thread: Input 2. {}
com.thoughtworks.xstream.converters.ConversionException: Could not call com.google.common.collect.Synchronized$SynchronizedSetMultimap.writeObject() : Could not call com.google.common.collect.HashMultimap.writeObject() : Could not call java.util.concurrent.ConcurrentLinkedQueue.writeObject() : null
---- Debugging information ----
message : Could not call java.util.concurrent.ConcurrentLinkedQueue.writeObject()
cause-exception : java.lang.StackOverflowError
cause-message : null
message : Could not call com.google.common.collect.HashMultimap.writeObject()
cause-exception : com.thoughtworks.xstream.converters.ConversionException
cause-message : Could not call java.util.concurrent.ConcurrentLinkedQueue.writeObject() : null
message : Could not call com.google.common.collect.Synchronized$SynchronizedSetMultimap.writeObject()
cause-message : Could not call com.google.common.collect.HashMultimap.writeObject() : Could not call java.util.concurrent.ConcurrentLinkedQueue.writeObject() : null
at com.thoughtworks.xstream.converters.reflection.SerializationMethodInvoker.callWriteObject(SerializationMethodInvoker.java:140)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at com.thoughtworks.xstream.converters.reflection.SerializableConverter.doMarshal(SerializableConverter.java:259)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.marshal(AbstractReflectionConverter.java:83)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at com.thoughtworks.xstream.core.AbstractReferenceMarshaller.convert(AbstractReferenceMarshaller.java:69)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at com.thoughtworks.xstream.core.TreeMarshaller.convertAnother(TreeMarshaller.java:58)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at com.thoughtworks.xstream.core.AbstractReferenceMarshaller$1.convertAnother(AbstractReferenceMarshaller.java:84)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.marshallField(AbstractReflectionConverter.java:250)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$2.writeField(AbstractReflectionConverter.java:226)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter$2.<init>(AbstractReflectionConverter.java:189)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doMarshal(AbstractReflectionConverter.java:135)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
After uninstall / install of the binding I don*t get any device any more and this exception:
2017-04-17 01:21:37.867 [ERROR] [ig.xml.osgi.XmlDocumentBundleTracker] - Could not send adding finished event for the module 'org.openhab.binding.zwave'!
java.lang.IllegalArgumentException: UID must have at least 2 segments.
at org.eclipse.smarthome.core.thing.UID.<init>(UID.java:65)[106:org.eclipse.smarthome.core.thing:0.9.0.201704011656]
at org.eclipse.smarthome.core.thing.UID.<init>(UID.java:43)[106:org.eclipse.smarthome.core.thing:0.9.0.201704011656]
at org.eclipse.smarthome.core.thing.type.ChannelTypeUID.<init>(ChannelTypeUID.java:35)[106:org.eclipse.smarthome.core.thing:0.9.0.201704011656]
at org.eclipse.smarthome.core.thing.xml.internal.ChannelXmlResult.toChannelDefinition(ChannelXmlResult.java:116)[107:org.eclipse.smarthome.core.thing.xml:0.9.0.201704011656]
at org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlResult.toChannelDefinitions(ThingTypeXmlResult.java:81)[107:org.eclipse.smarthome.core.thing.xml:0.9.0.201704011656]
at org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlResult.toThingType(ThingTypeXmlResult.java:129)[107:org.eclipse.smarthome.core.thing.xml:0.9.0.201704011656]
at org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlProvider.addingFinished(ThingTypeXmlProvider.java:145)[107:org.eclipse.smarthome.core.thing.xml:0.9.0.201704011656]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.addingFinished(XmlDocumentBundleTracker.java:220)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.access$6(XmlDocumentBundleTracker.java:215)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker$1.processBundle(XmlDocumentBundleTracker.java:141)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at org.eclipse.smarthome.config.xml.osgi.AbstractAsyncBundleProcessor$1.run(AbstractAsyncBundleProcessor.java:231)[98:org.eclipse.smarthome.config.xml:0.9.0.201704011656]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
