updated to OH 2.3 today and can’t see ComfoAir Binding in PaperUI anymore.
also missing BasicUI and other UI
RPI3
Logs?
no logs…
FULL template completion please !
When @Vaikis2006 opened up a new thread here, he was presented with:
* Platform information:
* Hardware: _CPUArchitecture/RAM/storage_
* OS: _what OS is used and which version_
* Java Runtime Environment: _which java platform is used and what version_
* openHAB version:
* Issue of the topic: please be detailed explaining your issue
* Please post configurations (if applicable):
* Items configuration related to the issue
* Sitemap configuration related to the issue
* Rules code related to the issue
* Services configuration related to the issue
* If logs where generated please post these here using code fences:
but he deleted all of that
There are (very good) reasons why people sat down and wrote this template…
Release = Raspbian GNU/Linux 8 (jessie)
Kernel = Linux 4.9.35-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
added required UI in /var/lib/openhab2/config/org/openhab/addons.config
and UI appeared
remaining issue with Comfoair binding which is not showing in PaperUI… previuosly I could see…
in events.log I get all values:
2018-06-02 10:01:25.443 [vent.ItemStateChangedEvent] - Lueftung_Aussentemperatur_Message changed from â 23.0°C, â 25.0°C to â 23.0°C, â 24.5°C
2018-06-02 10:01:25.449 [vent.ItemStateChangedEvent] - Lueftung_eff changed from -33.3333333333333333333333333333333300 to 0
2018-06-02 10:02:26.651 [vent.ItemStateChangedEvent] - Lueftung_Fortlufttemperatur changed from 24.5 to 25
2018-06-02 10:02:26.698 [vent.ItemStateChangedEvent] - Lueftung_Aussentemperatur_Message changed from â 23.0°C, â 24.5°C to â 23.0°C, â 25.0°C
2018-06-02 10:02:26.704 [vent.ItemStateChangedEvent] - Lueftung_eff changed from 0 to -33.3333333333333333333333333333333300
2018-06-02 10:03:27.947 [vent.ItemStateChangedEvent] - Lueftung_Aussenlufttemperatur changed from 23 to 22.5
2018-06-02 10:03:27.951 [vent.ItemStateChangedEvent] - Lueftung_Fortlufttemperatur changed from 25 to 24.5
2018-06-02 10:03:28.008 [vent.ItemStateChangedEvent] - Lueftung_Aussentemperatur_Message changed from â 23.0°C, â 25.0°C to â 22.5°C, â 24.5°C
2018-06-02 10:03:28.037 [vent.ItemStateChangedEvent] - Lueftung_eff changed from -33.3333333333333333333333333333333300 to 0
2018-06-02 10:06:31.702 [vent.ItemStateChangedEvent] - Lueftung_Aussenlufttemperatur changed from 22.5 to 23
2018-06-02 10:06:31.733 [vent.ItemStateChangedEvent] - Lueftung_Aussentemperatur_Message changed from â 22.5°C, â 24.5°C to â 23.0°C, â 24.5°C
In /var/lib/openhab2/config/org/openhab/addons.config
package = expert
Restart OH
no luck for me…
2018-06-02 14:11:07.205 [WARN ] [io.netty.bootstrap.ServerBootstrap ] - Unknown channel option ‘TCP_NODELAY’ for channel ‘[id: 0x12d64913]’
2018-06-02 14:11:07.269 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-package-expert’: Error restarting bundles:
Unable to acquire the state change lock for the module: osgi.identity; type=“osgi.bundle”; version:Version=“0.10.0.oh230”; osgi.identity=“org.eclipse.smarthome.mod el.script.runtime”; singleton:=“true” [id=139] STARTED [STARTED]
2018-06-02 14:11:10.791 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘airflow.rules’
2018-06-02 14:11:11.334 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-06-02 14:11:13.488 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled ‘openhab-package-simple’
2018-06-02 14:11:21.409 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule ‘Heat recovery efficiency’: Could not cast NULL to org. eclipse.smarthome.core.library.types.DecimalType; line 25, column 30, length 46
2018-06-02 14:11:21.422 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule ‘Lüfterstufe’: Could not cast NULL to org.eclipse.smar thome.core.library.types.DecimalType; line 200, column 10, length 39
2018-06-02 14:11:21.567 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule ‘Panasonic Heat control’: Could not cast NULL to org.ec lipse.smarthome.core.library.types.DecimalType; line 19, column 29, length 50
2018-06-02 14:11:28.359 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_3,4,6352227) has been shut down
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2] at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2] at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2] at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2] at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2] at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.2016022812 53] at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [85:org.eclipse.jetty.servlet:9.3.21.v20170918] at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.21.v20170918] at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9] at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.21.v20170918] at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.21.v20170918] at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.21.v20170918] at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.21.v20170918] at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9] at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.21.v20170918] at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.21.v20170918] at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.21.v20170918] at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.21.v20170918] at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9] at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.21.v20170918] at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.21.v20170918] at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [84:org.eclipse.jetty.server:9.3.21.v20170918] at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.21.v20170918] at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [76:org.eclipse.jetty.io:9.3.21.v20170918] at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [76:org.eclipse.jetty.io:9.3.21.v20170918] at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [76:org.eclipse.jetty.io:9.3.21.v20170918] at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [87:org.eclipse.jetty.util:9.3.21.v20170918] at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [87:org.eclipse.jetty.util:9.3.21.v20170918] at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [87:org.eclipse.jetty.util:9.3.21.v20170918] at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [87:org.eclipse.jetty.util:9.3.21.v20170918] at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [87:org.eclipse.jetty.util:9.3.21.v20170918] at java.lang.Thread.run(Thread.java:748) [?:?]
Caused by: org.glassfish.hk2.api.MultiException: A MultiException has 1 exceptions. They are:
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:106) ~[?:?] at org.jvnet.hk2.internal.FactoryCreator.dispose(FactoryCreator.java:173) ~[?:?] at org.jvnet.hk2.internal.SystemDescriptor.dispose(SystemDescriptor.java:526) ~[?:?] at org.glassfish.jersey.process.internal.RequestScope$Instance.remove(RequestScope.java:532) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2] at org.glassfish.jersey.process.internal.RequestScope$Instance.release(RequestScope.java:549) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2] at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:319) ~[169:org.glassfish.jersey.core.jersey-common:2.22.2] at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2] at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[170:org.glassfish.jersey.core.jersey-server:2.22.2] at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[167:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2] ... 31 more
Caused by: java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_3,4,6352227) has been shut down
at org.jvnet.hk2.internal.ServiceLocatorImpl.checkState(ServiceLocatorImpl.java:2288) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandleImpl(ServiceLocatorImpl.java:629) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:622) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:640) ~[?:?]
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:103) ~[?:?]
at org.glassfis
Sorry, not sure then
Comment the line back out I suppose
just removed /var/lib/openhab2/config/org/openhab/addons.config and rebooted, all fixed now
