- Platform information:
- Hardware: Orange PI
- OS: DietPi
- Java Runtime Environment: Zulu 8 (1.8.0_181)
- openHAB version: 2.5.M3
- Issue of the topic:
I issued the following command to check what the system was doing generally.
inotifywait -mr --exclude 0 /
And got this result
dietpi@DietPi:~$ inotifywait -mr --exclude 0 /
Setting up watches. Beware: since -r was given, this may take a while!
Watches established.
/proc/553/net/ OPEN if_inet6
/proc/553/net/ ACCESS if_inet6
/proc/553/net/ CLOSE_NOWRITE,CLOSE if_inet6
/proc/257/ OPEN cgroup
/proc/257/ ACCESS cgroup
/proc/257/ CLOSE_NOWRITE,CLOSE cgroup
/usr/share/openhab2/addons/ OPEN README
/usr/share/openhab2/addons/ ACCESS README
/usr/share/openhab2/addons/ CLOSE_NOWRITE,CLOSE README
Can anyone explain why is this thing happening. Is it intended?? or unusual??
Can someone try this command if your setup is on a RaspberryPi instead and tell if the result is similar?? Install with the following commands
sudo apt-get install inotify-tools
sudo nano /proc/sys/fs/inotify/max_user_watches
Increase number to 819200 and then save and then give command
