running the latest snapshot, I can not make knxd run at boot.
I installed and setup knxd via openhabian-config
The following message appears:
[11:27:16] root@openHABianPi:/home/openhabian# service knxd status
● knxd.service - KNX Daemon
Loaded: loaded (/lib/systemd/system/knxd.service; enabled)
Active: failed (Result: exit-code) since Sun 2017-12-31 11:26:48 CET; 30s ago
Process: 775 ExecStart=/usr/local/bin/knxd -p /run/knxd/knxd.pid $KNXD_OPTIONS (code=exited, status=1/FAILURE)
Main PID: 775 (code=exited, status=1/FAILURE)
Jan 01 01:00:16 openHABianPi systemd[1]: Started KNX Daemon.
Dec 31 11:26:48 openHABianPi knxd[775]: F00000000: [13:C.ipt] Link down, terminating
Dec 31 11:26:48 openHABianPi systemd[1]: knxd.service: main process exited, code=exited, status=1/FAILURE
Dec 31 11:26:48 openHABianPi systemd[1]: Unit knxd.service entered failed state.
[11:27:18] root@openHABianPi:/home/openhabian# cat /var/log/syslog | grep -i knxd
Dec 31 10:31:49 openHABianPi kernel: [322496.233650] [ 1904] 1001 1904 1206 53 7 0 36 0 knxd
Dec 31 10:33:28 openHABianPi knxd[736]: F00000000: [13:C.ipt] Link down, terminating
Dec 31 10:33:28 openHABianPi systemd[1]: knxd.service: main process exited, code=exited, status=1/FAILURE
Dec 31 10:33:28 openHABianPi systemd[1]: Unit knxd.service entered failed state.
[11:27:46] root@openHABianPi:/home/openhabian# service knxd restart
[11:28:06] root@openHABianPi:/home/openhabian# cat /var/log/syslog | grep -i knxd
[11:28:09] root@openHABianPi:/home/openhabian# service knxd status
Active: active (running) since Sun 2017-12-31 11:28:06 CET; 7s ago
Main PID: 1592 (knxd)
CGroup: /system.slice/knxd.service
└─1592 /usr/local/bin/knxd -p /run/knxd/knxd.pid --eibaddr=1.1.4 --client-addrs=1.1.129:8 -D -T -S -d -i --listen-local=/tmp/knx -b ipt:192.168…
Dec 31 11:28:06 openHABianPi systemd[1]: Started KNX Daemon.
A manual start works fine — as you can see!
Any hints?
