[Solved] OH2.5.12 Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.paper/[2.5.0,2.6)
Looks like the issue is back again???
addons.cfg all commented out except basic ui. data directory removed before restart.
# The base installation package of this openHAB instance (default is "standard")
# Valid options:
#   - minimal  : Installation only with dashboard, but no UIs or other addons
#   - standard : Typical installation with all standards UIs
#   - demo     : A demo setup which includes UIs, a few bindings, config files etc.
package = minimal
# Access Remote Add-on Repositories
# Defines whether the remote openHAB add-on repository should be used for browsing and installing add-ons.
# This not only makes latest snapshots of add-ons available, it is also required for the installation of
# any legacy 1.x add-on and all experimental features. (default is false for offline distro, true for online distro)
remote = true
# Include legacy 1.x bindings. If set to true, it also allows the installation of 1.x bindings for which there is
# already a 2.x version available (requires remote repo access, see above). (default is false)
legacy = true
# Include experimental add-ons. If set to true, it also allows the installation of extensions that are not (yet) part
# of the official distribution and need further testing (requires remote repo access, see above). (default is false)
experimental = true
# A comma-separated list of bindings to install (e.g. "sonos,knx,zwave")
#binding = caldav-command1,caldav-personal1,mqtt1,nest1,networkhealth1,ntp,squeezebox,weather1,chromecast,mqttitude1,plex1,panasonictv1,denon1,exec,expire1,amazonechocontrol,http1,unifi,networkupstools1
#yahooweather
# A comma-separated list of UIs to install (e.g. "basic,paper")
ui = basic
#,classic,habpanel,habmin,paper,habot
# A comma-separated list of persistence services to install (e.g. "rrd4j,jpa")
#persistence = influxdb
# A comma-separated list of actions to install (e.g. "mail,pushover")
#action = mail,xmpp
# A comma-separated list of transformation services to install (e.g. "map,jsonpath")
#transformation = map,scale,jsonpath,javascript
# A comma-separated list of voice services to install (e.g. "marytts,freetts")
#voice = marytts
# A comma-separated list of miscellaneous services to install (e.g. "myopenhab")
#misc =
Adding user openhab to group gpio
Done.
+ initialize_volume /openhab/conf /openhab/dist/conf
+ volume=/openhab/conf
+ source=/openhab/dist/conf
++ ls -A /openhab/conf
+ '[' -z 'html
icons
items
misc
persistence
rules
scripts
services
sitemaps
sounds
things
transform' ']'
+ initialize_volume /openhab/userdata /openhab/dist/userdata
+ volume=/openhab/userdata
+ source=/openhab/dist/userdata
++ ls -A /openhab/userdata
+ '[' -z 'config
etc
logs
tmp' ']'
++ cmp /openhab/userdata/etc/version.properties /openhab/dist/userdata/etc/version.properties
+ '[' '!' -z ']'
+ chown -R openhab:openhab /openhab
+ sync
+ '[' -d /etc/cont-init.d ']'
+ sync
+ '[' false == false ']'
++ IFS=' '
++ echo gosu openhab tini -s ./start.sh
+ '[' 'gosu openhab tini -s ./start.sh' == 'gosu openhab tini -s ./start.sh' ']'
+ command=($@ server)
+ exec gosu openhab tini -s ./start.sh server
Launching the openHAB runtime...
org.apache.karaf.features.internal.util.MultiException: Error:
	at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:91)
	at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72)
	at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:457)
	at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:452)
	at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:224)
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:393)
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062)
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
	at java.lang.Thread.run(Thread.java:748)
	Suppressed: java.io.IOException: Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.paper/[2.5.0,2.6)
		at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:77)
		at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
		at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)
		at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)
		... 3 more
	Caused by: java.io.IOException: Error resolving artifact org.openhab.ui.bundles:org.openhab.ui.paper:jar:[2.5.0,2.6): [Could not find metadata org.openhab.ui.bundles:org.openhab.ui.paper/maven-metadata.xml in local (/openhab/userdata/tmp/mvn), Could not find metadata org.openhab.ui.bundles:org.openhab.ui.paper/maven-metadata.xml in openhab (https://openhab.jfrog.io/openhab/libs-release/), Could not find metadata org.openhab.ui.bundles:org.openhab.ui.paper/maven-metadata.xml in openhab (https://openhab.jfrog.io/openhab/libs-release/)]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.configureIOException(AetherBasedResolver.java:803)
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:780)
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:657)
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:598)
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:565)
		at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:52)
		at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60)
		... 7 more
		Suppressed: shaded.org.eclipse.aether.transfer.MetadataNotFoundException: Could not find metadata org.openhab.ui.bundles:org.openhab.ui.paper/maven-metadata.xml in local (/openhab/userdata/tmp/mvn)
			at shaded.org.eclipse.aether.internal.impl.DefaultMetadataResolver.resolve(DefaultMetadataResolver.java:220)
			at shaded.org.eclipse.aether.internal.impl.DefaultMetadataResolver.resolveMetadata(DefaultMetadataResolver.java:178)
			at shaded.org.apache.maven.repository.internal.DefaultVersionRangeResolver.getVersions(DefaultVersionRangeResolver.java:198)
			at shaded.org.apache.maven.repository.internal.DefaultVersionRangeResolver.resolveVersionRange(DefaultVersionRangeResolver.java:148)
			at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveVersionRange(DefaultRepositorySystem.java:232)
			at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolveLatestVersionRange(AetherBasedResolver.java:1060)
			at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:765)
			... 12 more
		Suppressed: shaded.org.eclipse.aether.transfer.MetadataNotFoundException: Could not find metadata org.openhab.ui.bundles:org.openhab.ui.paper/maven-metadata.xml in openhab (https://openhab.jfrog.io/openhab/libs-release/)
			at shaded.org.eclipse.aether.connector.basic.MetadataTransportListener.transferFailed(MetadataTransportListener.java:48)
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:368)
			at shaded.org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:75)
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$DirectExecutor.execute(BasicRepositoryConnector.java:642)
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector.get(BasicRepositoryConnector.java:235)
			at shaded.org.eclipse.aether.internal.impl.DefaultMetadataResolver$ResolveTask.run(DefaultMetadataResolver.java:580)
			... 3 more
			... 3 more
	Caused by: shaded.org.eclipse.aether.resolution.VersionRangeResolutionException: Error resolving artifact org.openhab.ui.bundles:org.openhab.ui.paper:jar:[2.5.0,2.6)
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolveLatestVersionRange(AetherBasedResolver.java:1068)
		... 12 more```
