Ive installed bindings in the past ok with PaperUI but I have tried to install the weather binging and the SMAEnergy binding. Both spin forever and never go to installed. If I navigate away from the page after a while and come back, the binding shows as not installed.
more info again looking in Panel UI, under extensions - > user interfaces, I dont have an option for habpanel (which I have instlled)
Yet under Configuration - > services I have a Habpanel option and Hapbanel is running and working.
The last info post suggests an issue with Habpanle and I hope this helps with an answer?
I have Access remote repositiroies on and Include experimental Extensions on (which is all I thought you needed to get HabPanel to show as an option to install(?
It sounds a lot like your configuration database became corrupted somehow. Unfortunately the easiest way to fix this is to stop OH, delete the userdata/cache and userdata/tmp folder, and reinstall your addons (or use addons.cfg to list the addons to install instead of PaperUI).
Hi Rich thanks for the reply. I grabbed the latest snapshot of OH2 and copied it into my opt/openhab2 folder, rebooted and crossed my fingers. It all came back and can install and see all installed add ons now!
