- I have a clean package install on ubuntu 14.04 LTS with mysql persistence
- I used Paper UI to select mysql for persistence
- I created the database and database user with all privileges on the openhab database with grant option
create user ‘openhabuser’@’%’ identified by ‘XAZABC1;
grant all privileges on openhab.* to ‘openhabuser’@’%’ identified by ‘XAZABC1’ with grant option;
flush privileges;
- I modified ./services/mysql.cfg:
the database url like ‘jdbc:mysql://:/’ (without quotes)
url=jdbc:mysql://localhost:3306/openhab
user=openhabuser
password=XAZABC1
reconnectCnt=5
waitTimeout=10
localtime=true
- I created ./persistence/mysql.persist
Strategies {
// if no strategy is specified for an item entry below, the default list will be used
everyMinute : "0 * * * * ?"
every5Minutes : "0 */5 * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
// persist all items once a day and on every change and restore them from the db at startup
* : strategy = everyChange, everyDay, restoreOnStartup
// additionally, persist sm_ping every 5 minutes
sm_ping : strategy = every5Minutes, restoreOnStartup
- Starting openhab2 created two tables called Items and Item1 (ok)
- One record is persisted in each table (ok)
- Then there are a lot of errors logged and only every third record seems to be persisted:
2017-03-28 12:16:12.244 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2017-03-28 12:16:12.253 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2017-03-28 12:16:12.260 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
2017-03-28 12:19:03.563 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist’
2017-03-28 12:19:07.307 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2017-03-28 12:19:07.657 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-03-28 12:19:07.726 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-03-28 12:19:07.803 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-03-28 12:20:07.985 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2017-03-28 12:20:07.986 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2017-03-28 12:20:07.988 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Could not create entry for ‘network_device_192_168_56_101_time’ in table ‘Items’ with statement ‘INSERT INTO Items (ItemName) VALUES (?)’: No operations allowed after connection closed.
2017-03-28 12:20:07.988 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: tableName was null
2017-03-28 12:20:07.988 [ERROR] [sql.internal.MysqlPersistenceService] - Unable to store item ‘network_device_192_168_56_101_time’.
2017-03-28 12:21:07.939 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2017-03-28 12:21:07.940 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2017-03-28 12:21:07.940 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Error count exceeded 5. Disconnecting database.
2017-03-28 12:21:07.940 [WARN ] [sql.internal.MysqlPersistenceService] - mySQL: No connection to database. Can not persist item ‘network_device_192_168_56_101_time (Type=NumberItem, State=0.27998800000000001464428578401566483080387115478515625)’! Will retry connecting to database when error count:5 equals errReconnectThreshold:5
2017-03-28 12:22:07.952 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Error count exceeded 5. Disconnecting database.
2017-03-28 12:23:07.970 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2017-03-28 12:23:07.971 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Could not store item ‘network_device_192_168_56_101_time’ in database with statement ‘INSERT INTO Item2 (TIME, VALUE) VALUES(NOW(),?) ON DUPLICATE KEY UPDATE VALUE=?;’: No operations allowed after connection closed.
2017-03-28 12:24:07.939 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2017-03-28 12:24:07.940 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Connection is not valid!
2017-03-28 12:24:07.940 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Error count exceeded 5. Disconnecting database.
2017-03-28 12:24:07.940 [WARN ] [sql.internal.MysqlPersistenceService] - mySQL: No connection to database. Can not persist item ‘network_device_192_168_56_101_time (Type=NumberItem, State=0.246319000000000010164313835048233158886432647705078125)’! Will retry connecting to database when error count:5 equals errReconnectThreshold:5
What is going wrong?
Best regards
