Mail Action 1.12.0 SNAPSHOT
Have tried 2 different SMTP servers.
Same exception:
Could anyone confirm it is working for them?
2018-02-07 21:38:22.666 [ERROR] [rg.openhab.action.mail.internal.Mail] - Could not send e-mail to 'olemr@olemr.com'.
org.apache.commons.mail.EmailException: Sending the email to the following server failed : smtp@domeneshop.no:587
at org.apache.commons.mail.Email.sendMimeMessage(Email.java:1421) ~[?:?]
at org.apache.commons.mail.Email.send(Email.java:1448) ~[?:?]
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:157) ~[?:?]
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:89) ~[?:?]
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:67) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:215) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:82) ~[?:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$1(RuleEngineImpl.java:310) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
mail.cfg:
# The SMTP server hostname, e.g. "smtp.gmail.com"
hostname=smtp@domeneshop.no
# the SMTP port to use (optional, defaults to 25 (resp. 587 for TLS/SSL))
port=587
# the username and password if the SMTP server requires authentication
username=xxxx
password=xxxx
# The email address to use for sending mails
from=openhab@xxxx.com
# set to "true", if STARTTLS is enabled (not required) for the connection
# (optional, defaults to false)
tls=true
# set to "true", if SSL negotiation should occur on connection
# do not use both tls=true and ssl=true
ssl=false
# set to "true", if POP before SMTP (another authentication mechanism)
# should be enabled. Username and Password are taken from the above
# configuration (optional, default to false)
popbeforesmtp=false
# Character set used to encode message body
# (optional, if not provided platform default is used)
#charset=
