niccodemi
(nicco demi)
July 13, 2023, 6:00am
21
Hi, below is modified python script which I am using. It’s based on the one I found on following link
#!/usr/bin/python
import urllib, urllib2, hashlib, re, requests
from xml.etree import ElementTree as ET
from requests.auth import HTTPBasicAuth
#config
username = 'admin' #your inverter webpage username
password = 'admin' #your inverter webpage password
inverterIP = 'xxx.xxxx.xxx.xxx' #inverter ip address
#domoticz settings
domoticz_host = 'xxx.xxxx.xxx.xxx' #domoticz ip address
domoticz_port = '80'
domoticz_url = 'json.htm'
domoticz_ActualPower = 'xxx' # PV Device id domoticz
# Process html response
def processResponse(resp, strToken, strNextToken):
#parse response and get values
This file has been truncated. show original
#!/usr/bin/python
#config
username = 'USERNAME' #your inverter webpage username
password = 'PASSWORD' #your inverter webpage password
inverterIP = 'XXX.XXX.XXX.XXX' #inverter ip address
strTokenLen = len(strToken)
valueIndexToken = resp.find(strToken)
valueIndexNextToken = resp.find(strNextToken)
value = re.sub('[ =";]', '', resp[valueIndexToken+strTokenLen:valueIndexNextToken-5])
#print retreved values
return value
#fetch site from url
url = 'http://' + inverterIP + '/status.html'
try:
res = requests.get(url,auth=HTTPBasicAuth(username, password))
res.raise_for_status()
except requests.exceptions.HTTPError as err:
print err
sys.exit(1)
#gather values
inverter = processResponse(res.content, 'webdata_pv_type', 'webdata_rate_p')
totalToday = processResponse(res.content, 'webdata_today_e', 'webdata_total_e')
totalOveral = processResponse(res.content, 'webdata_total_e', 'webdata_alarm')
now = processResponse(res.content, 'webdata_now_p', 'webdata_today_e')
multiply='1000.0'
etotal1000 = float(totalOveral) * float(multiply)
strTotalOveral=str(etotal1000)
#print to console
print totalOveral
print totalToday
print now
niccodemi
(nicco demi)
July 13, 2023, 6:06am
22
This is the rule which gets the data from python script (via Wifi dongle connected to inverter)
rule "solar inverter"
//Time cron "0 0/5 * 1/1 * ? *" //normal
Time cron "0/30 0/1 * 1/1 * ? *" //(every 30 seconds - for testing)
//Time cron "0 44 13 ? * *" //https://github.com/jankeesder/getPVData/blob/master/getPVData.py
if(solarman.state == ON) {
var String invdata = executeCommandLine(Duration.ofSeconds(10),"/usr/bin/python", "/var/lib/openhab/INVT-inverter/getPVData.py")
invtstring.postUpdate(invdata)
// logInfo("results", invdata)
val data1 = invtstring.state.toString.split("\n").get(0)
// invttot.postUpdate(Float::parseFloat(String::format("%s",data1).replace(',','.')))
invttot.postUpdate(Float::parseFloat(data1))
// invttot.postUpdate(data1) //worked with OH 3.0
// postUpdate("invttot", "3.142")
val data2 = invtstring.state.toString.split("\n").get(1)
// invtday.postUpdate(data2)
invtday.postUpdate(Float::parseFloat(data2))
// invtday.postUpdate(Float::parseFloat(String::format("%s",data2).replace(',','.')))
val data3 = invtstring.state.toString.split("\n").get(2)
// invtcurrent.postUpdate(data3)
// postUpdate("invtcurrent", data3)
invtcurrent.postUpdate(Float::parseFloat(data3))
// invtcurrent.postUpdate(Float::parseFloat(String::format("%s",data3).replace(',','.')))
// logInfo("results", data1) // had //
// logInfo("test", invtstring.state.toString())
// logInfo("test", "Chars " + data1.length)
// logInfo("results", data2)
// logInfo("test", "Chars " + data2.length)
// logInfo("results", data3)
// logInfo("test", "Chars " + data3.length)
items
Switch solarman “solarman” { channel=“network:pingdevice:solarman:online”}
String invtstring “inverter string data”
Number invttot “inverter total [%.1f]” (gCharts)
Number invtday “inverter daily [%.1f]”
Number invtcurrent “inverter current power [%.1f]”
And thing
network:pingdevice:solarman [ hostname=“xxx.xxx.xxx.xxx”, retry=1, timeout=4000, refreshInterval=180000 ]
Great! Thanks. So if I understand I’ll have this “status.html” on my future INVT inverter where I can get the info from.
niccodemi
(nicco demi)
July 13, 2023, 7:54am
24
I don’t know about status.html and it’s future implementation.
