just tried to create a mqtt generic thing. That works well and the new ui is nice for that. But if i try to add a new channel i have a very simple problem. Is is possoble to create the channel. Than i click on done and the list of channels ist displayed, but i i lease the thing display and come back later to see my channels, al the channels are gone.
So the ui oder the binding does not save the channel definition.
@YSC i found the next thing with mqtt. I created a generic item and forgot to select the bridge. If iopen the thing, than going to config an try to select the brindge. The window is closed immediately after selecting the bridge and i am back in the list of things. The bridge is not selected. Working now on build #1945
It happens sometimes, the router becomes confused and going back goes back twice, I don’t know why. Probably should investigate harder. Normally refreshing the page makes the problem go away.
