openhabian 3.2.0 - Release Build
Ip = 192.168.1.68
Release = Raspbian GNU/Linux 11 (bullseye)
Kernel = Linux 5.15.32-v7l+
Platform = Finished Raspberry Pi bluetooth helper.
Uptime = 0 day(s). 0:9:50
CPU Usage = 7.05% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 1.51, 5m: 1.20, 15m: 0.87
I wanted to install my first ZigBee device while on OH2… since I read there is no support for it, I proceeded with OHv3 as follows:
- bought a rPi4 4GB and an Ember ZigBee dongle.
- installed openHABian on it
- used the openHABian menu to prepare the serial port (and rebooted)
- installed the ZigBee binding
- The Ember dongle was recognised as coordinator and has all fields populated and is online
UID: zigbee:coordinator_ember:9318fa5b77
label: Ember Coordinator
thingTypeUID: zigbee:coordinator_ember
configuration:
zigbee_port: /dev/ttyUSB0
zigbee_initialise: false
zigbee_channel: 11
zigbee_concentrator: 1
zigbee_trustcentremode: TC_JOIN_SECURE
zigbee_extendedpanid: C1A32EFB435B716E
zigbee_flowcontrol: 1
zigbee_baud: 115200
zigbee_panid: 56641
zigbee_powermode: 1
zigbee_txpower: 0
zigbee_networksize: 25
zigbee_linkkey: 5A6967426565416C6C69616E63653039
zigbee_childtimeout: 86400
zigbee_networkkey: 9872B87B6F19BAE34C8C7E439E37E470
zigbee_meshupdateperiod: 86400
- I also bought some Chinese Smart bulbs, but these do not connect to or cannot be found by the coordinator… following this description.
- I enabled logging in Karaf as described in the docs, but the log makes no sense to me.
2022-06-05 15:00:26.582 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:26.585 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=7, ackNum=2, reTx=false, data=F5 00 FF 00 18]
2022-06-05 15:00:26.593 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=2, ackNum=0, reTx=false, data=F5 80 FF 00 18 02]
2022-06-05 15:00:26.597 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=7, ackNum=2, reTx=false, data=F5 00 FF 00 18]
2022-06-05 15:00:26.599 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:26.599 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:26.602 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=3, notRdy=false]
2022-06-05 15:00:27.588 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:27.591 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=0, ackNum=3, reTx=false, data=F6 00 FF 00 18]
2022-06-05 15:00:27.599 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=3, ackNum=1, reTx=false, data=F6 80 FF 00 18 02]
2022-06-05 15:00:27.602 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=0, ackNum=3, reTx=false, data=F6 00 FF 00 18]
2022-06-05 15:00:27.604 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:27.604 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:27.607 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=4, notRdy=false]
2022-06-05 15:00:28.594 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:28.597 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=1, ackNum=4, reTx=false, data=F7 00 FF 00 18]
2022-06-05 15:00:28.605 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=4, ackNum=2, reTx=false, data=F7 80 FF 00 18 02]
2022-06-05 15:00:28.608 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=1, ackNum=4, reTx=false, data=F7 00 FF 00 18]
2022-06-05 15:00:28.610 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:28.610 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:28.613 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=5, notRdy=false]
2022-06-05 15:00:29.601 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:29.604 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=2, ackNum=5, reTx=false, data=F8 00 FF 00 18]
2022-06-05 15:00:29.611 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=5, ackNum=3, reTx=false, data=F8 80 FF 00 18 02]
2022-06-05 15:00:29.614 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=2, ackNum=5, reTx=false, data=F8 00 FF 00 18]
2022-06-05 15:00:29.616 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:29.616 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:29.619 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=6, notRdy=false]
2022-06-05 15:00:30.607 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:30.609 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=3, ackNum=6, reTx=false, data=F9 00 FF 00 18]
2022-06-05 15:00:30.617 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=6, ackNum=4, reTx=false, data=F9 80 FF 00 18 02]
2022-06-05 15:00:30.620 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=3, ackNum=6, reTx=false, data=F9 00 FF 00 18]
2022-06-05 15:00:30.622 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:30.623 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:30.625 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=7, notRdy=false]
2022-06-05 15:00:31.613 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:31.616 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=4, ackNum=7, reTx=false, data=FA 00 FF 00 18]
2022-06-05 15:00:31.624 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=7, ackNum=5, reTx=false, data=FA 80 FF 00 18 02]
2022-06-05 15:00:31.626 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=4, ackNum=7, reTx=false, data=FA 00 FF 00 18]
2022-06-05 15:00:31.629 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:31.629 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:31.631 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=0, notRdy=false]
2022-06-05 15:00:32.619 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:32.622 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=5, ackNum=0, reTx=false, data=FB 00 FF 00 18]
2022-06-05 15:00:32.629 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=0, ackNum=6, reTx=false, data=FB 80 FF 00 18 02]
2022-06-05 15:00:32.632 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=5, ackNum=0, reTx=false, data=FB 00 FF 00 18]
2022-06-05 15:00:32.635 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:32.635 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:32.637 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=1, notRdy=false]
2022-06-05 15:00:33.625 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:33.628 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=6, ackNum=1, reTx=false, data=FC 00 FF 00 18]
2022-06-05 15:00:33.636 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=1, ackNum=7, reTx=false, data=FC 80 FF 00 18 02]
2022-06-05 15:00:33.638 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=6, ackNum=1, reTx=false, data=FC 00 FF 00 18]
2022-06-05 15:00:33.641 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:33.641 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:33.643 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=2, notRdy=false]
2022-06-05 15:00:34.631 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:34.634 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=7, ackNum=2, reTx=false, data=FD 00 FF 00 18]
2022-06-05 15:00:34.641 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=2, ackNum=0, reTx=false, data=FD 80 FF 00 18 02]
2022-06-05 15:00:34.644 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=7, ackNum=2, reTx=false, data=FD 00 FF 00 18]
2022-06-05 15:00:34.647 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:34.647 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:34.649 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=3, notRdy=false]
2022-06-05 15:00:35.637 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:35.640 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=0, ackNum=3, reTx=false, data=FE 00 FF 00 18]
2022-06-05 15:00:35.647 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=3, ackNum=1, reTx=false, data=FE 80 FF 00 18 02]
2022-06-05 15:00:35.650 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=0, ackNum=3, reTx=false, data=FE 00 FF 00 18]
2022-06-05 15:00:35.653 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:35.653 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:35.655 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=4, notRdy=false]
2022-06-05 15:00:36.643 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:36.646 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=1, ackNum=4, reTx=false, data=FF 00 FF 00 18]
2022-06-05 15:00:36.654 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=4, ackNum=2, reTx=false, data=FF 80 FF 00 18 02]
2022-06-05 15:00:36.657 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=1, ackNum=4, reTx=false, data=FF 00 FF 00 18]
2022-06-05 15:00:36.659 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:36.659 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:36.663 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=5, notRdy=false]
2022-06-05 15:00:37.650 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:37.653 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=2, ackNum=5, reTx=false, data=00 00 FF 00 18]
2022-06-05 15:00:37.660 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=5, ackNum=3, reTx=false, data=00 80 FF 00 18 02]
2022-06-05 15:00:37.663 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=2, ackNum=5, reTx=false, data=00 00 FF 00 18]
2022-06-05 15:00:37.665 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:37.668 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 0
2022-06-05 15:00:37.670 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=6, notRdy=false]
2022-06-05 15:00:38.656 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:38.658 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=3, ackNum=6, reTx=false, data=01 00 FF 00 18]
2022-06-05 15:00:38.666 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=6, ackNum=4, reTx=false, data=01 80 FF 00 18 02]
2022-06-05 15:00:38.668 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=3, ackNum=6, reTx=false, data=01 00 FF 00 18]
2022-06-05 15:00:38.671 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:38.674 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 0
2022-06-05 15:00:38.676 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=7, notRdy=false]
2022-06-05 15:00:39.662 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:39.664 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=4, ackNum=7, reTx=false, data=02 00 FF 00 18]
2022-06-05 15:00:39.672 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=7, ackNum=5, reTx=false, data=02 80 FF 00 18 02]
2022-06-05 15:00:39.674 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=4, ackNum=7, reTx=false, data=02 00 FF 00 18]
2022-06-05 15:00:39.677 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:39.679 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 0
2022-06-05 15:00:39.682 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=0, notRdy=false]
2022-06-05 15:00:40.667 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:40.670 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=5, ackNum=0, reTx=false, data=03 00 FF 00 18]
2022-06-05 15:00:40.677 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=0, ackNum=6, reTx=false, data=03 80 FF 00 18 02]
2022-06-05 15:00:40.680 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=5, ackNum=0, reTx=false, data=03 00 FF 00 18]
2022-06-05 15:00:40.682 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:40.683 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 0
2022-06-05 15:00:40.685 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=1, notRdy=false]
2022-06-05 15:00:41.673 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:41.677 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=6, ackNum=1, reTx=false, data=04 00 FF 00 18]
2022-06-05 15:00:41.684 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=1, ackNum=7, reTx=false, data=04 80 FF 00 18 02]
2022-06-05 15:00:41.687 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=6, ackNum=1, reTx=false, data=04 00 FF 00 18]
2022-06-05 15:00:41.689 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:41.689 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:41.692 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=2, notRdy=false]
2022-06-05 15:00:42.680 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:42.682 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=7, ackNum=2, reTx=false, data=05 00 FF 00 18]
2022-06-05 15:00:42.690 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=2, ackNum=0, reTx=false, data=05 80 FF 00 18 02]
2022-06-05 15:00:42.693 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=7, ackNum=2, reTx=false, data=05 00 FF 00 18]
2022-06-05 15:00:42.696 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:42.696 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:42.699 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=3, notRdy=false]
2022-06-05 15:00:43.686 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:43.688 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=0, ackNum=3, reTx=false, data=06 00 FF 00 18]
2022-06-05 15:00:43.696 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=3, ackNum=1, reTx=false, data=06 80 FF 00 18 02]
2022-06-05 15:00:43.699 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=0, ackNum=3, reTx=false, data=06 00 FF 00 18]
2022-06-05 15:00:43.702 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:43.702 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:43.704 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=4, notRdy=false]
2022-06-05 15:00:44.692 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: TX EZSP queue size: 1
2022-06-05 15:00:44.694 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameData [frmNum=1, ackNum=4, reTx=false, data=07 00 FF 00 18]
2022-06-05 15:00:44.702 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - <-- RX ASH frame: AshFrameData [frmNum=4, ackNum=2, reTx=false, data=07 80 FF 00 18 02]
2022-06-05 15:00:44.705 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH: Frame acked and removed AshFrameData [frmNum=1, ackNum=4, reTx=false, data=07 00 FF 00 18]
2022-06-05 15:00:44.708 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH added EZSP frame to receive queue. Queue length 1
2022-06-05 15:00:44.708 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - ASH took EZSP frame from receive queue. Queue length 0
2022-06-05 15:00:44.711 [DEBUG] [e.ember.internal.ash.AshFrameHandler] - --> TX ASH frame: AshFrameAck [ackNum=5, notRdy=false]
2022-06-05 15:04:42.903 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBee scan for zigbee:coordinator_ember:9318fa5b77
2022-06-05 15:04:42.906 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Permit join to FFFC/0 for 60 seconds.
2022-06-05 15:04:42.910 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=null queueTime=0, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=--, permitDuration=60, tcSignificance=true]]
2022-06-05 15:04:42.913 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=1, sleepy=0/3
2022-06-05 15:04:42.916 [DEBUG] [transaction.ZigBeeTransactionManager] - FFFC/0: Sending ZigBeeTransaction [ieeeAddress=null queueTime=6, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=07, permitDuration=60, tcSignificance=true]]
2022-06-05 15:04:42.918 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 1 outstanding
2022-06-05 15:04:42.921 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=07, permitDuration=60, tcSignificance=true]
2022-06-05 15:04:42.925 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=FFFC/0, profile=0000, cluster=0036, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=07, rssi=--, lqi=--, payload=07 3C 01]
2022-06-05 15:04:42.929 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - CCCCCCFFFEA5F359: Added transaction to queue, len=1, transaction=ZigBeeTransaction [ieeeAddress=CCCCCCFFFEA5F359 queueTime=0, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=--, permitDuration=60, tcSignificance=true]]
2022-06-05 15:04:42.931 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=1, outstandingQueues=1, sleepy=0/3
2022-06-05 15:04:42.936 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendBroadcastResponse [networkId=0, status=EMBER_SUCCESS, sequence=EF]
2022-06-05 15:04:42.939 [DEBUG] [transaction.ZigBeeTransactionManager] - 0000/0: Sending ZigBeeTransaction [ieeeAddress=CCCCCCFFFEA5F359 queueTime=9, state=WAITING, sendCnt=0, command=ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=08, permitDuration=60, tcSignificance=true]]
2022-06-05 15:04:42.941 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerAdded: 2 outstanding
2022-06-05 15:04:42.944 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=08, permitDuration=60, tcSignificance=true]
2022-06-05 15:04:42.947 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=0036, addressMode=DEVICE, radius=8, apsSecurity=false, ackRequest=true, apsCounter=08, rssi=--, lqi=--, payload=08 3C 01]
2022-06-05 15:04:42.958 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_BROADCAST_LOOPBACK, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=EF], lastHopLqi=255, lastHopRssi=0, sender=0000, bindingIndex=255, addressIndex=255, messageContents=07 3C 01]
2022-06-05 15:04:42.977 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSendUnicastResponse [networkId=0, status=EMBER_SUCCESS, sequence=F0]
2022-06-05 15:04:42.980 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=F0], lastHopLqi=255, lastHopRssi=0, sender=0000, bindingIndex=255, addressIndex=255, messageContents=08 3C 01]
2022-06-05 15:04:42.983 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=0036, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=F0, rssi=0, lqi=FF, payload=08 3C 01]
2022-06-05 15:04:42.986 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - CCCCCCFFFEA5F359: Node update. NWK Address=0000
2022-06-05 15:04:42.989 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - CCCCCCFFFEA5F359: Node 0000 is not updated
2022-06-05 15:04:42.992 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=08, permitDuration=60, tcSignificance=true]
2022-06-05 15:04:42.995 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=08, permitDuration=60, tcSignificance=true]
2022-06-05 15:04:42.999 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspIncomingMessageHandler [networkId=0, type=EMBER_INCOMING_UNICAST, apsFrame=EmberApsFrame [profileId=0000, clusterId=8036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=F1], lastHopLqi=255, lastHopRssi=0, sender=0000, bindingIndex=255, addressIndex=255, messageContents=08 00]
2022-06-05 15:04:43.003 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX APS: ZigBeeApsFrame [sourceAddress=0000/0, destinationAddress=0000/0, profile=0000, cluster=8036, addressMode=DEVICE, radius=0, apsSecurity=false, ackRequest=false, apsCounter=F1, rssi=0, lqi=FF, payload=08 00]
2022-06-05 15:04:43.005 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - CCCCCCFFFEA5F359: Node update. NWK Address=0000
2022-06-05 15:04:43.009 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - CCCCCCFFFEA5F359: Node 0000 is not updated
2022-06-05 15:04:43.012 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX CMD: ManagementPermitJoiningResponse [0000/0 -> 0000/0, cluster=8036, TID=08, status=SUCCESS]
2022-06-05 15:04:43.015 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ManagementPermitJoiningResponse [0000/0 -> 0000/0, cluster=8036, TID=08, status=SUCCESS]
2022-06-05 15:04:43.018 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_DIRECT, indexOrDestination=0000, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY, EMBER_APS_OPTION_ENABLE_ADDRESS_DISCOVERY, EMBER_APS_OPTION_RETRY], groupId=0, sequence=F0], messageTag=08, status=EMBER_SUCCESS, messageContents=]
2022-06-05 15:04:43.022 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=08 state=RX_ACK
2022-06-05 15:04:43.025 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=08, state=RX_ACK, outstanding=2
2022-06-05 15:04:43.029 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=CCCCCCFFFEA5F359 queueTime=100, state=COMPLETE, sendCnt=1, command=ManagementPermitJoiningRequest [0000/0 -> 0000/0, cluster=0036, TID=08, permitDuration=60, tcSignificance=true]]
2022-06-05 15:04:43.032 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 1 outstanding
2022-06-05 15:04:43.035 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - CCCCCCFFFEA5F359: transactionComplete, state=COMPLETE, outstanding=0
2022-06-05 15:04:43.038 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=1, outstandingQueues=0, sleepy=0/3
2022-06-05 15:04:43.040 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state changed: nwk=0000, TID=08, event=RX_ACK, state=COMPLETE
2022-06-05 15:04:43.864 [DEBUG] [zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspMessageSentHandler [networkId=0, type=EMBER_OUTGOING_BROADCAST, indexOrDestination=FFFC, apsFrame=EmberApsFrame [profileId=0000, clusterId=0036, sourceEndpoint=0, destinationEndpoint=0, options=[EMBER_APS_OPTION_ENABLE_ROUTE_DISCOVERY], groupId=0, sequence=EF], messageTag=07, status=EMBER_SUCCESS, messageContents=]
2022-06-05 15:04:43.867 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - RX STA: msgTag=07 state=RX_ACK
2022-06-05 15:04:43.869 [DEBUG] [transaction.ZigBeeTransactionManager] - notifyTransactionProgress: TID=07, state=RX_ACK, outstanding=1
2022-06-05 15:04:43.873 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction complete: ZigBeeTransaction [ieeeAddress=null queueTime=964, state=COMPLETE, sendCnt=1, command=ManagementPermitJoiningRequest [0000/0 -> FFFC/0, cluster=0036, TID=07, permitDuration=60, tcSignificance=true]]
2022-06-05 15:04:43.876 [DEBUG] [transaction.ZigBeeTransactionManager] - transactionListenerRemoved: 0 outstanding
2022-06-05 15:04:43.878 [DEBUG] [e.transaction.ZigBeeTransactionQueue] - Broadcast: transactionComplete, state=COMPLETE, outstanding=0
2022-06-05 15:04:43.881 [DEBUG] [transaction.ZigBeeTransactionManager] - Transaction Manager: Send Next transaction. outstandingTransactions=0, outstandingQueues=0, sleepy=0/3
2022-06-05 15:04:43.883 [DEBUG] [zigbee.transaction.ZigBeeTransaction] - Transaction state changed: nwk=FFFC, TID=07, event=RX_ACK, state=COMPLETE
What I am asking here, and what I feel I need to address first: What brand of bulb should I buy to have something others have connected successfully?
… before I even contemplate troubleshooting.
Any hints appreciated.
On a more general note: as a long-term v1 and v2 user, I struggle with the v3 UI and terminology (at least at this early stage, where I just spent 8 hours reading and 1h playing.)
