Thank you - that’s the exact same config I use (even the zwave protocol
I guess I need to upgrade then…
Is not this inverted
Point_Status or Point_Control* isPointOf Equipment_Lock hasLocation (the location)
If no matching item found:
Equipment_Lock hasLocation (the location)If all results have the state
CLOSED
orOFF
: displayIf any result has the state
ON
orOPEN
: single result, display the icon ; multiple results, display the icon and the count.
Both Verisure and VolvoOnCall binding ON is locked?
I am not sure what you mean (typos?)
If my XC60 is locked, the switch is ON
So, you mean you use a Lock (equipment) within your Car (equipment as well).
Does this even work (equipment in equipment instead of equipment in location)?
By the way: the Blinds Badge is working after a restart.
They are shown, when not 0 - which is fine for me, because the badge icon looks like a lowered rollershutter anyway
Biggest issue for me is that when frondoor (verisure) is locked (ON) the badge shows unlocked.
But i have some cases with Equipment in Eguipment like Pool / Poolpump and it will be Car / Lock
And for me i also want to have blinds inverted, for me it is more interesting when blinds is down.
Alright, will try this as well.
That’s the case right? At least in my case:
The badge is shown when rollershutters are down (not fully up = 0) and disappear when fully up.
I have setup my blinds as 0 Up and 100 Down should i revert my numbers?
That’s exactly my setup and the icon shows, whenever I have (even slightly) lowered my rollershutters.
That’s how I prefer it (and you, too according to your comment above)
Now i changed my blinds to 0 down and 100 up then when i close them to 0 then have the Badge but just when it is fully closed 0.
By the way: sub-Equipment is possible.
Did not know this yet.
Yes i now, but if i for example use Equipment_Door with Sub equipment Equipment_Lock i do not get a badge for lock.
Understand.
Is this maybe because the Lock’ badge is only shown on the next level up?
Means: If you have the location Apartment and in there a location corridor, the lock in the corridor will only be shown on corridor and not two levels up to Apartment.
So this might be the case for sub-equipment as well!?
EDIT:
You are right:
I just put my Lock down one level (from Apartment, down to Apartment -> Door) and the Lock badge disappeared.
The things i want to have changed around badges is:
- Climate Control should include both Equipment_HVAC and Equipment_RadiatorControl
- Blinds icon should be inverted >0 or CLOSED should show icon
- Lock should be inverted ON = Locked
- Lock should look for sub Equipment e.q. Equipment_Door / Equipment_Lock
- BatteryLow badge for Equipment_Battery or sub Equipment_Battery
I agree (mostly).
- would be nice
- Is the case at my system (>0 -> badge shows up)
- Totally agree
- would be nice as well
- great idea
EDIT: After an upgrade 2 change to:
Badge is shown if Rollershutter is fully open (0)
Does the Lock show up at your Equipment “Car”?
I can see it in the Model View:
But it’s not in the Equipment View.
Yes i have it in Equipment View under Locks.
Me too, but not under the Car itself - do you?
Under Equipment Car i have my V70 and if i choose the Car i see the Lock
Equipment Backdoor doesn’t show up as door badge. Has do be “door”.
