I am using OHv2 with weather1, and just added a second location set to the existing config.
I made a mistake by adding a key that is not valid.
Later corrected it in the services/weather.cfg
, but it is not reflected in the /var/lib/openhab2/config/org/openhab/weather.config
I have read a few posts demonstrating the same issue: updates in weather.cfg not reflected in .config.
This seemingly appears to be an issue with the binding, as other bindings perfectly update their .config files.
I am just not savvy enough to read or even fix the binding.
How can I fix my current situation?
Is there an option for a force a reload, recreation via the console?
