Hi
Do you know any oil diffuser work with openhab please?
on the market I found a lot diffusers with smart app and google assistance compatible.
Is there any tutorial how to get api from device using google assistant, alexa.
Hi
Take a look at moodo they have a rest API for developers.https://moodo.co/smart-home/ I have no experience with this device but the price range is similar to others.
If this is not what your looking for maybe choose one that has a smart app, works with google/Alexa and IFTTT, this will give you several options to control via OH.
Hope this helps.
Thank you, moodo is to expensive. I wonder if it possible to get access to it. What kinde options do I have. I know there is connection to app on phone, contraction to aleksa, amazone echo.
Unless someone else can verify, the only way is to buy and try or contact them and ask.
Yes, the best solution is to ask them.
I’ve had a situation when I wanted to buy a baby humidifier for our daughter and I wanted it to be compatible with openhab. I’ve bought one but, unfortunately, it didn’t work with smart apps at all. Then I’ve decided to read more about it and found the right one (I’ve called twice to the manufacturer to prove the information I’ve read). So it’s just an experience thing.
What about this cheap model (on amazon you can find a lot of different like this) https://www.amazon.de/dp/B081X273J3/ref=sr_1_6?crid=PXRTTUMVFU66&keywords=aroma%2Bdiffuser%2Böl%2Bfernbedinung&qid=1581602584&sprefix=Aroma%2BDiffuser%2B%2Caps%2C211&sr=8-6&th=1
It remote controller looks like chinese RF433. So can be controlled easiely.
