I’m a newbie and have been trying and searching a lot over the weekend with limited success as it relates to the challenge below: 3 Hue 210 bulbs in a lamp with 3 fixtures which should be controlled all at once, i.e. I want to control the lamp, not the individual bulbs.
According to the Hue binding documentation, every device supports On/Off via a switch channel, so I created a switch channel for each bulb and a group like I did for color and color_temperature. Setting the color via colorpicker ((incl turn on/off) works, as does the color_temperature slider. But what doesn’t work is the separate switch. Can anyone shed some light what I’m doing wrong?
Thanks, both for your fast responses. I corrected the typo, amended the group as suggested, and even commented out everything else, to reduce it to the bare minimum, see below. On the UI the switch works, but it doesn’t control the bulbs, the %d counter also stays at zero (which seems logical)
Same result: the bulbs don’t go on/off. I set them on/off via the Hue app to be able to check, However, the %d parameter is now empty , shows (-), whereas before it was showing (0)
with Group:Switch:OR(ON,OFF) ColorSwitch “Alle Lampen [(%d)]”
2018-11-19 11:34:15.740 [ome.event.ItemCommandEvent] - Item ‘ColorSwitch’ received command ON
2018-11-19 11:34:15.756 [ome.event.ItemCommandEvent] - Item ‘ColorSwitch1’ received command ON
2018-11-19 11:34:15.763 [ome.event.ItemCommandEvent] - Item ‘ColorSwitch2’ received command ON
2018-11-19 11:34:15.775 [ome.event.ItemCommandEvent] - Item ‘ColorSwitch3’ received command ON
2018-11-19 11:34:15.809 [vent.ItemStateChangedEvent] - ColorSwitch1 changed from OFF to ON
2018-11-19 11:34:15.816 [vent.ItemStateChangedEvent] - ColorSwitch2 changed from OFF to ON
2018-11-19 11:34:15.822 [vent.ItemStateChangedEvent] - ColorSwitch3 changed from OFF to ON
with Group:Switch ColorSwitch “All Lamps [(%d)]”
2018-11-19 11:34:59.561 [ome.event.ItemCommandEvent] - Item ‘ColorSwitch’ received command ON
2018-11-19 11:34:59.589 [ome.event.ItemCommandEvent] - Item ‘ColorSwitch1’ received command ON
2018-11-19 11:34:59.612 [ome.event.ItemCommandEvent] - Item ‘ColorSwitch2’ received command ON
2018-11-19 11:34:59.625 [ome.event.ItemCommandEvent] - Item ‘ColorSwitch3’ received command ON
2018-11-19 11:34:59.657 [vent.ItemStateChangedEvent] - ColorSwitch1 changed from NULL to ON
2018-11-19 11:34:59.663 [GroupItemStateChangedEvent] - ColorSwitch changed from ON to UNDEF through ColorSwitch1
2018-11-19 11:34:59.667 [vent.ItemStateChangedEvent] - ColorSwitch2 changed from NULL to ON
2018-11-19 11:34:59.671 [GroupItemStateChangedEvent] - ColorSwitch changed from UNDEF to ON through ColorSwitch3
2018-11-19 11:34:59.677 [vent.ItemStateChangedEvent] - ColorSwitch3 changed from NULL to ON
what’s interesting is that without the OR the group does not seem to propagate the state change to ColorSwitch2
Same thing, whether I have 1,2 or 3 bulbs in the group (both variants of the group). However, as I was looking at the logs I noticed that the system was complaining about a possible mismatch between the sitemap name and the sitemap file name, so I corrected this. The sitemap file is now called “default.sitemap” and the sitemap itself is called “sitemap”. Yet it still does not work, the only thing that has changed is that the %d parameter now shows the correct number of bulbs in both group variants. I tried both group variants with 1,2 or 3 bulbs respectively, have switched them on before, one bulb set to red, the second one to blue and the third to white, all clearly visible colours/brightness. Log file says they get the off command, but the lamps continue to shine happily
// Group ColorWheel
// Group ColorTemperature
// Group ColorSwitch
Group:Switch ColorSwitch "All Lamps [(%d)]" <light>
// Group:Switch:OR(ON,OFF) ColorSwitch "All Lamps [(%d)]" <light>
// Color ColorWheel1 (ColorWheel) {channel="hue:0210:001788215454:7:color"}
// Color ColorWheel2 (ColorWheel) {channel="hue:0210:001788215454:8:color"}
// Color ColorWheel3 (ColorWheel) {channel="hue:0210:001788215454:13:color"}
// Dimmer ColorTemperature1 (ColorTemperature) {channel="hue:0210:001788215454:7:color_temperature"}
// Dimmer ColorTemperature2 (ColorTemperature) {channel="hue:0210:001788215454:8:color_temperature"}
// Dimmer ColorTemperature3 (ColorTemperature) {channel="hue:0210:001788215454:13:color_temperature"}
Switch ColorSwitch1 (ColorSwitch) {channel="hue:0210:001788215454:7:switch"}
// Switch ColorSwitch2 (ColorSwitch) {channel="hue:0210:001788215454:8:switch"}
// Switch ColorSwitch3 (ColorSwitch) {channel="hue:0210:001788215454:13:switch"}
log files:
with Group:Switch:OR(ON,OFF) ColorSwitch "All Lamps [(%d)]" <light>
2018-11-19 11:52:58.014 [ome.event.ItemCommandEvent] - Item 'ColorSwitch' received command OFF
2018-11-19 11:52:58.025 [ome.event.ItemCommandEvent] - Item 'ColorSwitch1' received command OFF
2018-11-19 11:52:58.070 [vent.ItemStateChangedEvent] - ColorSwitch1 changed from ON to OFF
with Group:Switch ColorSwitch "All Lamps [(%d)]" <light>
2018-11-19 11:59:17.858 [ome.event.ItemCommandEvent] - Item 'ColorSwitch' received command OFF
2018-11-19 11:59:17.873 [ome.event.ItemCommandEvent] - Item 'ColorSwitch1' received command OFF
2018-11-19 11:59:17.889 [vent.ItemStateChangedEvent] - ColorSwitch1 changed from ON to OFF
The Group does all it is supposed to; sending it a command ON sends a command ON to it’s members. It’s not a group problem if members don’t respond to ON.
Simplify to a sitemap switch representing just one member. Does that work? I don’t know anything about hue, so I don’t know how that should be configured.
Guys, thanks so much for your assistance and time to look into it, I really appreciate it!
I simplified it to the max, renamed groups and bulbs for greater clarity (Simplicity?)…but it doesn’t work. I’ll try a reboot (even though this is not Windows :-), maybe that helps
Group:Switch:OR(ON,OFF) with_or "With OR [(%d)]"
Switch Bulb_with_or (with_or) {channel="hue:0210:001788215454:7:switch"}
Group:Switch without_or "Without OR [(%d) bulbs]"
Switch Bulb_without_or (without_or) {channel="hue:0210:001788215454:7:switch"}
log files:
2018-11-19 12:36:04.693 [ome.event.ItemCommandEvent] - Item 'with_or' received command OFF
2018-11-19 12:36:04.716 [ome.event.ItemCommandEvent] - Item 'Bulb_with_or' received command OFF
2018-11-19 12:36:04.735 [vent.ItemStateChangedEvent] - Bulb_with_or changed from ON to OFF
2018-11-19 12:36:06.165 [ome.event.ItemCommandEvent] - Item 'without_or' received command OFF
2018-11-19 12:36:06.178 [ome.event.ItemCommandEvent] - Item 'Bulb_without_or' received command OFF
2018-11-19 12:36:06.202 [vent.ItemStateChangedEvent] - Bulb_without_or changed from ON to OFF
Okay, so it’s nothing to do with groups. Your device does not respond to an ON/OFF command to the Item. You can see autoupdate changing the state in the log, so you kno the command is getting there.
Trying a different approach: I switched off the lamp via a hue switch (hardware, that works ). Log files show me that the color channel went from 300,99,100 (red, on) to 300,99,0 (red, off), 257,98,100 (blue, on) to 257,98,0 (blue, off) and 84,47,100 (white, on) to 84,47,0 (white, off).
Is there a way that I can send input to the color channel myself, using variables or anything like that and mimic an on/off behavior? And then use a switch with mappings somehow on top of the item/the group?
This frustrates me - seems such an obvious thing one want to do: turn on/off a lamp with several bulbs with 1 click
But then something is wrong with the documentation if switch really isn’t supported, at least how I read it. There is a matrix in the middle of the doc page that states:
The following matrix lists the capabilities (channels) for each type:
Thing type
On/Off
Brightness
Color
Color Temperature
0000
X
0010
X
0100
X
X
0110
X
X
0200
X
X
0210
X
X
X
0220
X
X
X
According to the X for On/off in row 0210 the switch should be working if I’m reading it correctly.
But thanks for your snippet, Mihai, I’ll try that.
Yup, it was the "SOME of the following " that made me think that it works, as it did not say “the following devices support these channels”…and yes, I know it sounds pedantic, but really, it made me spend 3 hours now trying to figure it out
