ok. I’ve tried out your binding Rev 2.5.0.201901231931.
All Things appear in PaperUI as online. But still there’s no value/state available.
The TRACE log shows up:
Jan 23 21:37:06 pfarr-kg-pi 'onewire: basic:owbridge:Temp_Schlaf' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
Jan 23 21:37:06 pfarr-kg-pi 'onewire: basic:owbridge:V_Keller2' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
Jan 23 21:37:06 pfarr-kg-pi 'onewire: basic:owbridge:V_Keller1' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
Jan 23 21:37:06 pfarr-kg-pi registering discovery service for org.openhab.binding.onewire.internal.handler.OwserverBridgeHandler@1857e19
Jan 23 21:37:06 pfarr-kg-pi ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=303, service.bundleid=238, service.scope=singleton} - org.openhab.binding.onewire
Jan 23 21:37:06 pfarr-kg-pi 'onewire: owserver:owbridge' changed from UNINITIALIZED to INITIALIZING
Jan 23 21:37:06 pfarr-kg-pi 'onewire: owserver:owbridge' changed from INITIALIZING to UNKNOWN
Jan 23 21:37:06 pfarr-kg-pi 'onewire: owserver:owbridge' changed from UNKNOWN to ONLINE
Jan 23 21:37:06 pfarr-kg-pi opened OwServerConnection to 127.0.0.1:4304
Jan 23 21:37:06 pfarr-kg-pi 'onewire: basic:owbridge:Temp_Bad' changed from UNINITIALIZED to INITIALIZING
Jan 23 21:37:06 pfarr-kg-pi 'onewire: basic:owbridge:Temp_Bad' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): required properties missing
Jan 23 21:37:06 pfarr-kg-pi 'onewire: basic:owbridge:Temp_Keller' changed from UNINITIALIZED to INITIALIZING
Jan 23 21:37:06 pfarr-kg-pi 'onewire: basic:owbridge:Temp_Keller' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): required properties missing
Jan 23 21:37:06 pfarr-kg-pi 'onewire: basic:owbridge:Temp_Wohn' changed from UNINITIALIZED to INITIALIZING
Jan 23 21:37:06 pfarr-kg-pi 'onewire: basic:owbridge:Temp_Wohn' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): required properties missing
Jan 23 21:37:06 pfarr-kg-pi 'onewire: basic:owbridge:V_Bad' changed from UNINITIALIZED to INITIALIZING
Jan 23 21:37:06 pfarr-kg-pi 'onewire: basic:owbridge:V_Bad' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): required properties missing
Jan 23 21:37:07 pfarr-kg-pi refreshTask starts at 1548275827820, 14 childs
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:Temp_Schlaf (14 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:Temp_Schlaf not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:Temp_Wohn (13 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:Temp_Wohn not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:Temp_Flur (12 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:Temp_Flur not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:Temp_Bad (11 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:Temp_Bad not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:Temp_Keller (10 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:Temp_Keller not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:V_Schlaf (9 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:V_Schlaf not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:V_Wohn1 (8 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:V_Wohn1 not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:V_Wohn2 (7 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:V_Wohn2 not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:V_Wohn3 (6 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:V_Wohn3 not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:V_Bad (5 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:V_Bad not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:V_Bad_Heizkoerper (4 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:V_Bad_Heizkoerper not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:V_Keller1 (3 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:V_Keller1 not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:V_Keller2 (2 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:V_Keller2 not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi refresh: getting handler for onewire:basic:owbridge:V_Reserve (1 to go)
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:V_Reserve not initialized, skipping refresh
Jan 23 21:37:07 pfarr-kg-pi update: getting handler for onewire:basic:owbridge:Temp_Bad (13 total in list)
Jan 23 21:37:07 pfarr-kg-pi owServerConnection already open, skipping input buffer
Jan 23 21:37:07 pfarr-kg-pi wrote: messageType READ, size 46, controlFlags 0x00000104, payload '/28.FFE342811603/type'
Jan 23 21:37:07 pfarr-kg-pi Scheduled Astro event-jobs for thing astro:sun:local
Jan 23 21:37:07 pfarr-kg-pi read: return code 7, size 31, controlFlags 0x00000104, payload 'DS18B20'
Jan 23 21:37:07 pfarr-kg-pi Discovery Result with UID 'astro:moon:local' has been removed.
Jan 23 21:37:07 pfarr-kg-pi Thing 'onewire:basic:owbridge:Temp_Bad' has been updated.
Jan 23 21:37:07 pfarr-kg-pi updated modelid/vendor to DS18B20 / Dallas/Maxim
Jan 23 21:37:07 pfarr-kg-pi configuring sensors for onewire:basic:owbridge:Temp_Bad
Jan 23 21:37:07 pfarr-kg-pi onewire: basic:owbridge:Temp_Bad sucessfully updated properties, removing from property update list
Jan 23 21:37:07 pfarr-kg-pi 'onewire: basic:owbridge:Temp_Bad' changed from OFFLINE (CONFIGURATION_ERROR): required properties missing to UNKNOWN
Jan 23 21:37:08 pfarr-kg-pi refreshing onewire:basic:owbridge:Temp_Bad
Jan 23 21:37:08 pfarr-kg-pi owServerConnection already open, skipping input buffer
Jan 23 21:37:08 pfarr-kg-pi wrote: messageType PRESENT, size 41, controlFlags 0x00000124, payload '/28.FFE342811603'
Jan 23 21:37:09 pfarr-kg-pi read: return code 0, size 32, controlFlags 0x00000124, payload '(��B�??V'
Jan 23 21:37:09 pfarr-kg-pi presence /28.FFE342811603 : ON
Jan 23 21:37:09 pfarr-kg-pi refreshing sensor 0 (/28.FFE342811603)
Jan 23 21:37:09 pfarr-kg-pi 'onewire: basic:owbridge:Temp_Bad' changed from UNKNOWN to ONLINE
Jan 23 21:37:09 pfarr-kg-pi owServerConnection already open, skipping input buffer
Jan 23 21:37:09 pfarr-kg-pi wrote: messageType READ, size 55, controlFlags 0x00000104, payload '/28.FFE342811603/temperature11'
Jan 23 21:37:09 pfarr-kg-pi Started Dashboard at http://192.168.178.100:8080
Jan 23 21:37:09 pfarr-kg-pi Started Dashboard at https://192.168.178.100:8443
Jan 23 21:37:09 pfarr-kg-pi read: return code 12, size 36, controlFlags 0x00000104, payload ' 21.25'
Jan 23 21:37:09 pfarr-kg-pi read temperature 21.25 °C from /28.FFE342811603
Jan 23 21:37:09 pfarr-kg-pi update: getting handler for onewire:basic:owbridge:Temp_Keller (12 total in list)
Jan 23 21:37:09 pfarr-kg-pi wrote: messageType READ, size 46, controlFlags 0x00000104, payload '/28.FFEF86731605/type'
Jan 23 21:37:09 pfarr-kg-pi read: return code 7, size 31, controlFlags 0x00000104, payload 'DS18B20'
Jan 23 21:37:09 pfarr-kg-pi updated modelid/vendor to DS18B20 / Dallas/Maxim
Jan 23 21:37:09 pfarr-kg-pi Thing 'onewire:basic:owbridge:Temp_Keller' has been updated.
Jan 23 21:37:09 pfarr-kg-pi onewire: basic:owbridge:Temp_Keller sucessfully updated properties, removing from property update list
Jan 23 21:37:09 pfarr-kg-pi configuring sensors for onewire:basic:owbridge:Temp_Keller
Jan 23 21:37:09 pfarr-kg-pi 'onewire: basic:owbridge:Temp_Keller' changed from OFFLINE (CONFIGURATION_ERROR): required properties missing to UNKNOWN
Jan 23 21:37:12 pfarr-kg-pi refreshing sensor 0 (/28.FF26CD311704)
Jan 23 21:37:12 pfarr-kg-pi owServerConnection already open, skipping input buffer
Jan 23 21:37:12 pfarr-kg-pi wrote: messageType READ, size 55, controlFlags 0x00000104, payload '/28.FF26CD311704/temperature11'
Jan 23 21:37:12 pfarr-kg-pi read: return code 12, size 36, controlFlags 0x00000104, payload ' 21.5'
Jan 23 21:37:12 pfarr-kg-pi read temperature 21.5 °C from /28.FF26CD311704
Jan 23 21:37:12 pfarr-kg-pi update: getting handler for onewire:basic:owbridge:V_Bad (10 total in list)
Jan 23 21:37:12 pfarr-kg-pi wrote: messageType READ, size 46, controlFlags 0x00000104, payload '/29.F31E26000000/type'
Jan 23 21:37:12 pfarr-kg-pi read: return code 6, size 30, controlFlags 0x00000104, payload 'DS2408'
Jan 23 21:37:12 pfarr-kg-pi updated modelid/vendor to DS2408 / Dallas/Maxim
Jan 23 21:37:12 pfarr-kg-pi Thing 'onewire:basic:owbridge:V_Bad' has been updated.
Jan 23 21:37:12 pfarr-kg-pi onewire: basic:owbridge:V_Bad sucessfully updated properties, removing from property update list
Jan 23 21:37:12 pfarr-kg-pi configuring sensors for onewire:basic:owbridge:V_Bad
Jan 23 21:37:12 pfarr-kg-pi adding state description for channel onewire:basic:owbridge:V_Bad:digital0
Jan 23 21:37:12 pfarr-kg-pi configured onewire:basic:owbridge:V_Bad channel 0: path=[org.openhab.binding.onewire.internal.device.OwDeviceParameterMap@4b7520], mode=INPUT, logic=NORMAL
Jan 23 21:37:12 pfarr-kg-pi adding state description for channel onewire:basic:owbridge:V_Bad:digital1
Jan 23 21:37:12 pfarr-kg-pi configured onewire:basic:owbridge:V_Bad channel 1: path=[org.openhab.binding.onewire.internal.device.OwDeviceParameterMap@fc7983], mode=INPUT, logic=NORMAL
Jan 23 21:37:12 pfarr-kg-pi adding state description for channel onewire:basic:owbridge:V_Bad:digital2
Jan 23 21:37:12 pfarr-kg-pi configured onewire:basic:owbridge:V_Bad channel 2: path=[org.openhab.binding.onewire.internal.device.OwDeviceParameterMap@79a67b], mode=INPUT, logic=NORMAL
Jan 23 21:37:12 pfarr-kg-pi adding state description for channel onewire:basic:owbridge:V_Bad:digital3
Jan 23 21:37:12 pfarr-kg-pi configured onewire:basic:owbridge:V_Bad channel 3: path=[org.openhab.binding.onewire.internal.device.OwDeviceParameterMap@8ae181], mode=INPUT, logic=NORMAL
Jan 23 21:37:12 pfarr-kg-pi adding state description for channel onewire:basic:owbridge:V_Bad:digital4
Jan 23 21:37:12 pfarr-kg-pi configured onewire:basic:owbridge:V_Bad channel 4: path=[org.openhab.binding.onewire.internal.device.OwDeviceParameterMap@1b5029d], mode=OUTPUT, logic=INVERTED
Jan 23 21:37:12 pfarr-kg-pi adding state description for channel onewire:basic:owbridge:V_Bad:digital5
Jan 23 21:37:12 pfarr-kg-pi configured onewire:basic:owbridge:V_Bad channel 5: path=[org.openhab.binding.onewire.internal.device.OwDeviceParameterMap@247103], mode=INPUT, logic=NORMAL
Jan 23 21:37:12 pfarr-kg-pi adding state description for channel onewire:basic:owbridge:V_Bad:digital6
Jan 23 21:37:12 pfarr-kg-pi configured onewire:basic:owbridge:V_Bad channel 6: path=[org.openhab.binding.onewire.internal.device.OwDeviceParameterMap@818094], mode=INPUT, logic=NORMAL
Jan 23 21:37:12 pfarr-kg-pi adding state description for channel onewire:basic:owbridge:V_Bad:digital7
Jan 23 21:37:12 pfarr-kg-pi configured onewire:basic:owbridge:V_Bad channel 7: path=[org.openhab.binding.onewire.internal.device.OwDeviceParameterMap@1166299], mode=INPUT, logic=NORMAL
Jan 23 21:37:12 pfarr-kg-pi 'onewire: basic:owbridge:V_Bad' changed from OFFLINE (CONFIGURATION_ERROR): required properties missing to UNKNOWN
Jan 23 21:37:13 pfarr-kg-pi refreshing onewire:basic:owbridge:V_Bad
Jan 23 21:37:13 pfarr-kg-pi owServerConnection already open, skipping input buffer
Jan 23 21:37:13 pfarr-kg-pi wrote: messageType PRESENT, size 41, controlFlags 0x00000124, payload '/29.F31E26000000'
Jan 23 21:37:13 pfarr-kg-pi read: return code 0, size 32, controlFlags 0x00000124, payload ')�?&???�'
Jan 23 21:37:13 pfarr-kg-pi presence /29.F31E26000000 : ON
Jan 23 21:37:13 pfarr-kg-pi Z_Bad changed from NULL to ON
Jan 23 21:37:13 pfarr-kg-pi refreshing sensor 0 (/29.F31E26000000)
Jan 23 21:37:13 pfarr-kg-pi 'onewire: basic:owbridge:V_Bad' changed from UNKNOWN to ONLINE
Jan 23 21:37:13 pfarr-kg-pi wrote: messageType READ, size 61, controlFlags 0x00000104, payload 'uncached/29.F31E26000000/sensed.BYTE'
Jan 23 21:37:13 pfarr-kg-pi read: return code 12, size 36, controlFlags 0x00000104, payload ' 255'
Jan 23 21:37:13 pfarr-kg-pi wrote: messageType READ, size 50, controlFlags 0x00000104, payload '/29.F31E26000000/PIO.BYTE'
Jan 23 21:37:13 pfarr-kg-pi read: return code 12, size 36, controlFlags 0x00000104, payload ' 0'
Jan 23 21:37:13 pfarr-kg-pi /29.F31E26000000 IN0: raw {0, 1, 2, 3, 4, 5, 6, 7}, final ON
Jan 23 21:37:13 pfarr-kg-pi /29.F31E26000000 IN1: raw {0, 1, 2, 3, 4, 5, 6, 7}, final ON
Jan 23 21:37:13 pfarr-kg-pi /29.F31E26000000 IN2: raw {0, 1, 2, 3, 4, 5, 6, 7}, final ON
Jan 23 21:37:13 pfarr-kg-pi /29.F31E26000000 IN3: raw {0, 1, 2, 3, 4, 5, 6, 7}, final ON
Jan 23 21:37:13 pfarr-kg-pi /29.F31E26000000 OUT4: raw {}, final ON
Jan 23 21:37:13 pfarr-kg-pi /29.F31E26000000 IN5: raw {0, 1, 2, 3, 4, 5, 6, 7}, final ON
Jan 23 21:37:13 pfarr-kg-pi /29.F31E26000000 IN6: raw {0, 1, 2, 3, 4, 5, 6, 7}, final ON
Jan 23 21:37:13 pfarr-kg-pi /29.F31E26000000 IN7: raw {0, 1, 2, 3, 4, 5, 6, 7}, final ON
Jan 23 21:37:13 pfarr-kg-pi update: getting handler for onewire:basic:owbridge:V_Wohn3 (9 total in list)
Jan 23 21:37:13 pfarr-kg-pi wrote: messageType READ, size 46, controlFlags 0x00000104, payload '/29.F31E26000000/type'
Jan 23 21:37:13 pfarr-kg-pi read: return code 6, size 30, controlFlags 0x00000104, payload 'DS2408'
Jan 23 21:37:13 pfarr-kg-pi updated modelid/vendor to DS2408 / Dallas/Maxim
Jan 23 21:37:13 pfarr-kg-pi Thing 'onewire:basic:owbridge:V_Wohn3' has been updated.
Jan 23 21:37:13 pfarr-kg-pi onewire: basic:owbridge:V_Wohn3 sucessfully updated properties, removing from property update list
Jan 23 21:37:13 pfarr-kg-pi configuring sensors for onewire:basic:owbridge:V_Wohn3
Jan 23 21:37:13 pfarr-kg-pi adding state description for channel onewire:basic:owbridge:V_Wohn3:digital0
Jan 23 21:37:13 pfarr-kg-pi configured onewire:basic:owbridge:V_Wohn3 channel 0: path=[org.openhab.binding.onewire.internal.device.OwDeviceParameterMap@cb9b4d], mode=INPUT, logic=NORMAL
