I’ve resetted the DEVOLO MT2653 to factory default and did an inclusion once again.
The new node ID is 62.
The interesting thing is that now the configuration is send and received directly after pressing button 2 in management mode. This will increase the lifetime of the battery very much.
The items were changed accordingly:
Number RC_DEVOLO_01_Scene_Number "RC_01_DEVOLO_MT2653: Scene Number" <switch> { channel="zwave:device:c1f45758:node62:scene_number" }
Number RC_DEVOLO_01_Battery_Level "RC_01_DEVOLO_MT2653: Battery Level" <battery> (G_BATTERY_DEVICES) { channel="zwave:device:c1f45758:node62:battery-level" }
The channel received updates (value 255) if any button were pressed. The action for each assoziation group is set to default (Switch On/Off and Dim).
I changed that the action to “Send senses” and the same problem occurs again.
Then I tried “Send Preconfigured Scenses” without luck.
I scrolled the whole list of available option done to the end and found “Central scene to gateway”
I changed all actions to that value:
That’s working!!
(Hint: I used filter “node 62|node62” in frontail. That’s the reason why my items aren’t shown)
One thing to note is: The scene value changed from integer (11,21,31,41,…) to decimal (1.0, 2.0, 5.0, 6.0)!
2018-08-20 21:07:44.903 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 62: Application Command Request (ALIVE:DONE)
2018-08-20 21:07:44.905 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Starting initialisation from DONE
2018-08-20 21:07:44.910 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 62: Incoming command class CENTRAL_SCENE
2018-08-20 21:07:44.912 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 62: Received CENTRAL_SCENE command V1
2018-08-20 21:07:44.915 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 62: Received scene 1 at key 0 [Single Press]
2018-08-20 21:07:44.920 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-08-20 21:07:44.922 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Got a value event from Z-Wave network, endpoint = 0, command class = CENTRAL_SCENE, value = 1.0
2018-08-20 21:07:44.925 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:c1f45758:node62:scene_number to 1.0 [DecimalType]
2018-08-20 21:07:45.873 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 62: Application Command Request (ALIVE:DONE)
2018-08-20 21:07:45.875 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Starting initialisation from DONE
2018-08-20 21:07:45.880 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 62: Incoming command class CENTRAL_SCENE
2018-08-20 21:07:45.882 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 62: Received CENTRAL_SCENE command V1
2018-08-20 21:07:45.884 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 62: Received scene 5 at key 0 [Single Press]
2018-08-20 21:07:45.889 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-08-20 21:07:45.891 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Got a value event from Z-Wave network, endpoint = 0, command class = CENTRAL_SCENE, value = 5.0
2018-08-20 21:07:45.894 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:c1f45758:node62:scene_number to 5.0 [DecimalType]
2018-08-20 21:07:46.964 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 62: Application Command Request (ALIVE:DONE)
2018-08-20 21:07:46.967 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Starting initialisation from DONE
2018-08-20 21:07:46.975 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 62: Incoming command class CENTRAL_SCENE
2018-08-20 21:07:46.978 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 62: Received CENTRAL_SCENE command V1
2018-08-20 21:07:46.982 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 62: Received scene 6 at key 0 [Single Press]
2018-08-20 21:07:46.990 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-08-20 21:07:46.994 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Got a value event from Z-Wave network, endpoint = 0, command class = CENTRAL_SCENE, value = 6.0
2018-08-20 21:07:46.998 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:c1f45758:node62:scene_number to 6.0 [DecimalType]
2018-08-20 21:07:47.527 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 62: Application Command Request (ALIVE:DONE)
2018-08-20 21:07:47.530 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Starting initialisation from DONE
2018-08-20 21:07:47.536 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 62: Incoming command class CENTRAL_SCENE
2018-08-20 21:07:47.539 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 62: Received CENTRAL_SCENE command V1
2018-08-20 21:07:47.542 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 62: Received scene 2 at key 0 [Single Press]
2018-08-20 21:07:47.548 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-08-20 21:07:47.551 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Got a value event from Z-Wave network, endpoint = 0, command class = CENTRAL_SCENE, value = 2.0
2018-08-20 21:07:47.554 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:c1f45758:node62:scene_number to 2.0 [DecimalType]
Here’s a small log including everything (From message button pressed up to a rule log)
2018-08-20 21:10:44.850 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 3E 05 5B 03 02 00 05 94
2018-08-20 21:10:44.854 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-08-20 21:10:44.857 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 04 00 3E 05 5B 03 02 00 05 94
2018-08-20 21:10:44.861 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0B 00 04 00 3E 05 5B 03 02 00 05 94
2018-08-20 21:10:44.864 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 3E 05 5B 03 02 00 05
2018-08-20 21:10:44.868 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 62: Application Command Request (ALIVE:DONE)
2018-08-20 21:10:44.872 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 62: Starting initialisation from DONE
2018-08-20 21:10:44.876 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@15383f7 already registered
2018-08-20 21:10:44.880 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 62: Incoming command class CENTRAL_SCENE
2018-08-20 21:10:44.884 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 62: Received CENTRAL_SCENE command V1
2018-08-20 21:10:44.887 [DEBUG] [dclass.ZWaveCentralSceneCommandClass] - NODE 62: Received scene 5 at key 0 [Single Press]
2018-08-20 21:10:44.891 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2018-08-20 21:10:44.895 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-08-20 21:10:44.899 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Got a value event from Z-Wave network, endpoint = 0, command class = CENTRAL_SCENE, value = 5.0
2018-08-20 21:10:44.904 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:c1f45758:node62:scene_number to 5.0 [DecimalType]
2018-08-20 21:10:44.911 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 39: Transaction not completed: node address inconsistent. lastSent=39, incoming=255
2018-08-20 21:10:44.916 [thome.event.ItemStateEvent] - RC_DEVOLO_01_Scene_Number updated to 5.0
2018-08-20 21:10:44.920 [vent.ItemStateChangedEvent] - RC_DEVOLO_01_Scene_Number changed from 2.0 to 5.0
2018-08-20 21:10:44.921 [INFO ] [ipse.smarthome.model.script.r_RC_001] - rule r_RC_DEVOLO_01_Scene_Number_chgd (1)
SOLUTION: Take care that the action is set to "Central scene to gateway"
@sihui: Many thanks for your very quick response and directing me to the place to look at!
Regards
Norbert
