[SOLVED] Openhab 2 and executeCommandLine / Exec
I tried without sudo, it runs but fails because it cant load files etc. So needs to run as sudo
Thanks, doing this fixed it:
As it is mentioned in this post 36 there is no password.
So adding the user openhab to the sudoers with no password should help.
 sudo visudo -f /etc/sudoers.d/010_pi-nopasswd
Adding following lines
openhab ALL=(ALL) NOPASSWD: ALL
First, THANK YOU for using visudo. I’m always amazed at how many people don’t and then argue with me after they trash their system that they like nano better.
Secondly, please don’t give OH permission to run anything with sudo without password. You may as well run OH as root. Replace the last ALL with the full path to the command that you want OH to be able to run without password, which in this case would be the path to your backup.sh script. This will allow the openhab user to only run that one command without a password, all others will require a password.
Hi Rich
Like so?
openhab ALL=(ALL) NOPASSWD: /etc/openhab2/scripts/backup.sh
That looks right.
Hi Rich
trying to expand on this to allow ‘openhab-cli backup’ be executed by the openhab user, rather than requiring a password for sudo.
I made this change:
openhab ALL=(ALL) NOPASSWD: /usr/bin/openhab-cli
but it appears executing that from the command line still requires a password. Any thoughts?
By default the openhab-cli script is owned by root:root
How would i be able to have openhab user execute that?
I think you can list the commands all on one line separated by a comma.
openhab ALL=(ALL) NOPASSWD: /etc/openhab2/scripts/backup.sh, /usr/bin/openhab-cli
If that doesn’t work, you can create an alias. See
Thanks Rich, im not sure its working
kris@openhab2:~$ sudo -u openhab openhab-cli backup
openHAB 2.x.x backup script
Please run this script as root! (e.g. use sudo)
kris@openhab2:~$
if I run it as root, it works and doesnt ask for a password but I assume its using root:root
You are missing a sudo.
The sudo -u openhab part of the line runs the script as the openhab user. Then you want to run sudo openhab-cli backup to start as the openhab user and test that openhab can call that script with sudo.
sudo -u openhab sudo openhab-cli backup
Goodness!
OK. It appears the visudo modification didnt work. Time to look at an alias - i assume a command alias?
kris@openhab2:~$ sudo -u openhab sudo openhab-cli backup
[sudo] password for kris:
kris@openhab2:~$
I’m trying to replicate the @@ space replacement in executeCommandLine, but can’t get it working.
curl command works directly from openHab commandline, so user rights should be sufficient.
Running the rule doesn’t do what it should supposed to.
rules file:
rule "Write NordPool energy prices to Influxdb"
			Item Renew_price changed
			//executeCommandLine("curl@@-i@@-XPOST@@'http://192.168.50.30:8086/write?db=openhab_db'@@--data-binary@@'NP_Electricity_price_test@@value=999@@1435362189575692185'")
            //logInfo("Write NordPool energy prices to Influxdb", results)
log:
2019-03-23 21:47:41.662 [INFO ] [lipse.smarthome.io.net.exec.ExecUtil] - executed commandLine '[curl, -i, -XPOST, 'http://192.168.50.30:8086/write?db=openhab_db', --data-binary, 'NP_Electricity_price_test, value=999, 1435362189575692185']'
what is the secret of passing the command with executeCommandLine?
Add a time out argument to the call to executeCommandLine in milliseconds and log out the result of the call. If curl is returning an error it is almost certainly printing an ear message and that will let you see the message.
i did change the rules to the following:
			//executeCommandLine("curl -i -XPOST 'http://192.168.50.30:8086/write?db=openhab_db' --data-binary 'NP_Electricity_price_test value=999 1435362189575692185'",5000)
 			executeCommandLine("curl@@-i@@-XPOST@@'http://192.168.50.30:8086/write?db=openhab_db'@@--data-binary@@'NP_Electricity_price_test@@value=999@@1435362189575692185'@@",1000)
            logInfo("Write NordPool energy prices to Influxdb","results")
log:
2019-03-24 11:02:36.577 [vent.ItemStateChangedEvent] - Renew_price changed from ON to OFF
2019-03-24 11:02:36.707 [INFO ] [e NordPool energy prices to Influxdb] - results
command did not execute, as previously.
I’m trying to follow your reference documentation:
https://community.openhab.org/t/how-to-solve-exec-binding-problems/18131
I have updated my rule a bit to get the results.
			//executeCommandLine("curl -i -XPOST 'http://192.168.50.30:8086/write?db=openhab_db' --data-binary 'NP_Electricity_price_test value=919 1435362189575692186'",5000)
 			val results = executeCommandLine("curl@@-i@@-XPOST@@'http://192.168.50.30:8086/write?db=openhab_db'@@--data-binary@@'NP_Electricity_price_test@@value=919@@1435362189575692186'", 1000)
            logInfo("NPpriceDB.rules",results)
log:
2019-03-24 13:10:31.717 [INFO ] [arthome.model.script.NPpriceDB.rules] - curl: (1) Protocol "'http" not supported or disabled in libcurl
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0curl: (6) Could not resolve host: value=919
curl: (6) Could not resolve host: 1435362189575692186'
Same rule without spaces @@ replacement:
			val results = executeCommandLine("curl -i -XPOST 'http://192.168.50.30:8086/write?db=openhab_db' --data-binary 'NP_Electricity_price_test value=919 1435362189575692180'",5000)
 			//val results = executeCommandLine("curl@@-i@@-XPOST@@'http://192.168.50.30:8086/write?db=openhab_db'@@--data-binary@@'NP_Electricity_price_test@@value=919@@1435362189575692186'", 1000)
gives timestamp error.
log:
2019-03-24 13:23:35.246 [INFO ] [arthome.model.script.NPpriceDB.rules] -   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
100   162  100   105  100    57  17549   9526 --:--:-- --:--:-- --:--:-- 21000
HTTP/1.1 400 Bad Request
Content-Type: application/json
Request-Id: 43562332-4e27-11e9-8309-b827eb81a147
X-Influxdb-Build: OSS
X-Influxdb-Error: unable to parse '"NP_Electricity_price_test value=919 1435362189575692180"': bad timestamp
X-Influxdb-Version: 1.7.4
X-Request-Id: 43562332-4e27-11e9-8309-b827eb81a147
Date: Sun, 24 Mar 2019 11:23:35 GMT
Content-Length: 105
{"error":"unable to parse '\"NP_Electricity_price_test value=919 1435362189575692180\"': bad timestamp"}
also I see that quotation marks have switched from single quote to double quote.
this one worked:
			val results = executeCommandLine("curl@@-i@@-XPOST@@http://192.168.50.30:8086/write?db=openhab_db@@--data-binary@@NP_Electricity_price_test value=919 1435362189575692180@@",5000)
log:
2019-03-24 14:11:59.474 [INFO ] [arthome.model.script.NPpriceDB.rules] -   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
100    55    0     0  100    55      0   3358 --:--:-- --:--:-- --:--:--  3666
HTTP/1.1 204 No Content
Request-Id: 06646066-4e2e-11e9-85d2-b827eb81a147
X-Request-Id: 06646066-4e2e-11e9-85d2-b827eb81a147
Date: Sun, 24 Mar 2019 12:11:59 GMT
I removed all internal quote marks and I don’t understand how this could work as curl command needs those according to syntax. Totally illogical solution…
I don’t think the double quotes you are seeing are coming from your command. I think curl is adding them to say “I can’t parse the stuff between the double quotes”. Beyond that I won’t be if much more help. I don’t use curl that much. I don’t use executeCommandLine that much either so I’m out of ideas for how to help.
Hej there,
looking at our code, I was wondering about the timers behavior if you don’t send arguments like “now.plusMinutes(5)”. When will the timer expire?
Thank you
