please help----
sitemap demo label=“Main Menu”
Frame {
Text item=Temperature
Chart item=Temperature period=D refresh=3000
items
Number Temperature “Outside Temperature” { channel=“yahooweather:weather:berlin:temperature” }
things
yahooweather:weather:berlin [ location=638242 ]
Strategies {
everyMinute:“0 * * * * ?”
default = everyChange
Items {
Temperature : strategy = everyUpdate, everyMinute
opus
(Jürgen Baginski)
2
What isn’t working? The Text or the Chart don’t show any value?
Are you sure that values are written into an .rrd file? (see here)
the chart is not working…i not touch services/rrd4j.cfg…i only create the rrd4j.persist file in the persistence folder
Strategies {
Items {
opus
(Jürgen Baginski)
4
Did you check the .rrd files are existing?
Using the REST Api you can even check each entry into the rrd4j database.
solved-----i use the demo setup and change it with my items…thanks
